The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
ltseung888
Dear Forever,
Thank you for doing and showing the experiments.
I believe you will continue with the Tong Po Chi improvement of having 2 coils and 1 magnet.  It is much better than the original experiment 1 of having 1 coil and 2 magnets.
If we focus on using magnetic attraction for both coils and one coil having more turns than the other, we can test for the unbalanced force.  This type of unbalanced force is expected to be larger and easier to control.  There will be no degrading due to collision.  The Magnet will continue to keep its strong magnetism as the pulsing current will always try to magnetise the magnet.
The first set of experiments can be done by hand â€" pushing the buttons to provide the pulses.  The later experiments will be done automatically via timers.  The frequency will determine the number of pulses per second which is related to the magnitude of the Unbalaned Force on the device.
This is the true explanation of the anti-gravity effect with pulsing current.
Good luck and continue your good work with the experiments.
Lawrence Tseung
Director,
Help Seedings Innovate Foundation Limited
Forever
http://www.youtube.com/watch?v=EwmOPb38meQ
This experiment 8a uses repulsion from both coils. The magnet is first repelled to the LHS by one coil. It is then repelled by the other coil. Such action can be made automatic via the use of timers. The unbalanced force can then be demonstrated and measured.
;D ;D
Forever
http://www.youtube.com/watch?v=U4bNDDP3d1k
This experiment 8b uses both coils as attraction. However, one coil has more turns than the other. The magnet is first attracted towards the RHS. It can then be attracted back by the other coil. The same motion can thus be repeated. Because of the difference in turns in the two coils and unbalanced force can be produced.
;D ;D
Forever
http://www.youtube.com/watch?v=jJ-e0OcGT_c
This experiment 8c uses attraction on one coil and repulsion on the other. Since both action moves the magnet to the LHS. We need to push the magnet back by hand thus this set up cannot be automatic.
;D ;D
Top Gun
Quote from: Forever on May 04, 2009, 01:18:52 AM
This experiment 8c uses attraction on one coil and repulsion on the other. Since both action moves the magnet to the LHS. We need to push the magnet back by hand - thus this set up cannot be automatic.
;D ;D
Dear Forever,
Your videos and the explanations made things easy.  There will be no doubts on the validity of the experiments.
I look forward to the remaining experiments.
