The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
lltfdaniel1
Quote from: ltseung888 on July 20, 2009, 05:49:25 AM
Just finished speaking to Mr. Cheung King Fung, the Golden-Year Chairman of the Hong Kong Invention Association.
The earliest demonstration of our working prototype can be July 28, Tuesday, 3pm at the Office of the Association.
Members and guests are encouraged to bring their video cameras.
I shall get a HKIA member to videotape and report that event.
This will be one of the many dry-runs in Hong Kong.
You can google search the Hong Kong Invention Association for its background first.
At least two professors will be invited.
To ITseung.
Can you take a nice long read of this?
http://www.panaceauniversity.org/Magnetic%20Resonant%20Amplifier.pdf
And explain it with your lead out?
Thanks.
Dan
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
ltseung888
Quote from: lltfdaniel1 on July 20, 2009, 06:22:41 AM
To ITseung.
Thanks.
Dan
Let me summarize the Lead-Out Energy theory and apply it to the Magnetic Resonance Amplifier.
1.   The Law of Conservation of Energy states that Energy cannot be created or destroyed.  It can, however, change from one form to another.
2.   If the energy input to a machine is 100 units, the energy coming out from that machine must be less than 100 units as some will be used to overcome friction and other losses.
3.   The Lead-Out Energy theory states that there are many existing energies in the Universe that we are not using effectively at present.  One example is gravity.  Another example is electromagnetism which is a result of electron motion.
4.   With a Lead-Out Energy machine, some of the Input Energy is used to Lead-Out the existing energy discussed in 3 into the machine.  Thus if the input energy is 100 units and leads another 50 units of existing energy into the system, the effective input energy into the system is 150 units.  Thus the output can be up to 150 units.
5.   The entire universe is under the gravitational pull of the stars, suns, planets etc.  If such forces can be used to do work, we effectively have unlimited energy.  Mankind can use gravitational energy such as driving a turbine at the bottom of a dam.  However, the water must be evaporated by the Sun and rain down to fill the dam again.
6.   Lee Cheung Kin made the greatest breakthrough in December 2004 when he realized that pulling a pendulum could lead out gravitational energy.  The lead-out energy is equal to the vertical component of the tension of the string times the vertical displacement.
7.   Lawrence Tseung worked with Mr. Lee and extended the theory to cover the magnetic pendulum, the vibrating and rotating systems etc.  In their patent application, they stated that they could lead-out energy via pulse forces from oscillating, vibrating, rotating systems.  The energy can be gravitational, magnetic, electric, electromagnetic etc.
8.   The pulse forces must be applied at the appropriate time.  Most people associate that with resonance.  The Tong Po Chi prototype demonstrated that the frequency is not a single resonance frequency but one that changes with external environment (e.g. load).
The Magnetic Resonance Amplifier is likely to be an example of leading-out electron motion energy (in terms of electromagnetic waves) as it has magnets, coils, current, etc.  Previously, most such inventions were rejected because the patent office or the scientists could not identify the source of energy.  They were not taught the Lead-Out Energy theory.  The Lead-Out energy theory does not violate the Law of Conservation of Energy.  It supplements it.
Hope that helps!
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited
chrisC
Quote from: TinselKoala on July 20, 2009, 05:25:27 AM
www.google.com
search terms: 360TECHNOLOGIES high point north carolina
Hmm...I give up. The furniture store? The software company?
I guess I'll just have to call the number. At least the area code checks out. Good for You, you got that part right at least.
@TK
Sometimes, depending on which one of the persona surfaces, and which one was last involved in some delusion, it's possible to change from furniture business to technology companies, like changing from non-functional mechanical pendulums to electromagnetic coils, magnetic power etc etc. It's all in the mind. Even Google can't keep up with Lawrence's mind(s)!
Let's just assume it's the furniture company for now. What's the difference?
cheers
chrisC
blueplanet
May I ask if you have a self-running prototype available?
If you have, are you going to demontrate your self-running prototype on 28 July?
ltseung888
Quote from: blueplanet on July 20, 2009, 12:16:40 PM
The star is likely to be:
http://www.youtube.com/watch?v=jFS-e2R67u0&feature=channel_page
Bring your camera, measuring instruments and confirm overunity.
