hydroxy powered motor
Started by Motorcoach1, July 21, 2007, 05:55:58 PM
Motorcoach1
More Drawings HPM - I'm still trying to learn the new CAd programÃ,  Ã,  Ã, Ã,  the rotor cam in the center is the pink foam cam as in the first posts on page 1 the bearings ride on the flat side of the rotor cam , in the drawings the bearings have not been drawn in , look at the bottom- side view drawing and see the rotor cam the bearings get bolted in the piston rod ( one piston on each end ) and ride on the Cam face. The slide bar, the piston rod mounts in keeps the mecanisim from trying to roll over at higher speeds , thats at the top of the drawing and side veiw. As the piston fires it puts pressure on the rotor cam and makes the rotor turn.
Motorcoach1
Up Date> I'm building a Proto type model out of plexi glass so everyone can see how this things works and give you a better understanding of the mechanical aspects. most parts are done , hopefully by this week end I'll be assembling the motor and have photos of the parts and put together some of the assembly. The bearings I have will be the right size and due to an order screwup I'll be using the single row bearing instead of the double row , which is what is needed. Bearing No#6201 open (no shield). You will need 12 of these , I'll post these along with the other parts on a list soon. Thank you Mike
buckeyept49
? WELL WHERE IS IT? !!!! DID EVERYONE STOP WORKING ON THE HHO POWERED MOTOR?
Motorcoach1
  Thanks for asking I just had to many irons in the fire and had to scale back a little till some things get done , But still tinker with it. need a cad guy to do a dx file of the rotor  to send to a machine shop and thats the first big step.
khabe
hi,
Just looked this thread, have not read all comments, perhaps someone mentioned about ... may be ...
But why not to use car Air Conditioner compressor - I have took apart one Japan made one - exact the same design you are planning,
It need to be hardly rebuilt of course but at least main parts are well machined ... DIY those parts ... Im not sure you can do it well.
Cheers,
khabe
http://en.wikipedia.org/wiki/Swashplate_engine
An alternate design replaces the plate with a sine-shaped cam, and is thus known as a cam engine ...  air conditioner pumps
prilliant old designs about http://www.dself.dsl.pipex.com/MUSEUM/POWER/unusualICeng/axial-ICeng/axial-IC.htm
videos http://www.axialvectorengine.com/
