MACEDONIA CD questions
Started by MACEDONIA CD, July 22, 2007, 08:32:02 AM
MACEDONIA CD
hi to all
WHAT IS HAPEN TO ME
  I LIKE TO ASK SOMETHING
  IS  S.M TPU  IS LIKE THE TESLA  COIL    BUT  WHIT ANTHER  SECUNDARY COIL   IN THE ATHER SAID
IF CREATED  BIG VOLTAGE  IN THE  PRIMARY COIL  THEN IN THE SECONDARY COIL  IS  INCREASE  THE VOLTAGE   THEN IN ATHER  END OF THE SECUNDARY COIL MAKE  ATHER  COIL  HO IS THE OUT PUT   COIL HO  COLECTING ONLY  A  ELEKTRIC ENERGY    NOT A ELE. MAGNET.
  WE PUT 150 Khz  INPUT  HIT HIGH VOLTAGE  THEN IS PRODUCED  A  VERY HIGH  VOLTAGE  HO  IS ABLE TO MOVE ELEKTRONES  EASY  IN THE  SECUNDARY COLI
  <<<<<<<<<<  I SAID  YOU HAVE  SPEED  OF LIGHT  ONLY YOU NEED  TO INCREASE  VOLTAGE TO CREATED  BIG  ELEKTRONES  TO MOVE  WHIT  LONGITUDIAL   I MEAN
90 DEEGREES  IS LIKE TO MOVE  A  ELEKTRONES IN THE HORISONTAL  LINE  .
THEN YOU GET MOVING ELEKTRONES  IN LINE  IN THE  WIRES   <<  IF YOU MAKE  BIG  FREKFENCY  IN Mhz  THEN YOU GET  A   MORE COMPRES  ELKTRONES HO WHILL  MOVE WHIT  SPEED OF LIGHT
        <<<   1 ----  YOU NEED  BIG VOTAGE  ONLY FOR A CREATED  BIG ELEKTRON
        <<<<  2______ YOU NEED  HIGH  FREK.  ONLY TO CREATED  A  LONGITUDIAL WAVE  TO  MOVE ELEKTRONES  I HORISONTAL  LINE
         <<<< 3 ______ YOU NEED   ANTHER SECUNDARY  RECIVER  COIL  HO WHILL  CATCH  THIS  BIG ELKTRONES  HO IS MOVING  IN THE  HORISONTAL LINE
         <<<< 4 THEN YOU  GET  ONLY  ELEKTRICAL  FORCE   NOT MAGNET  FORCE  TO GET THE OUT POWER
   IS POSBLE  IS
MACEDONIA CD
hi
i whant to ask about  tpu   what you thing  is this posible  the tpu  is like a tesla  coil  i read some  patent  and  i thing is  posible  is the same divices
i read some phisics  formules  and i find some  good things
....  i read  and  i find  the free elktrones  i mean  1 elektron  to push  anther elktron   must be  in the <<<
   _8
10    this time is very important  to move elektrones like a train  >>>i read some  and find  is posible  to created  cool  lighting  from  bulb  <<<if you  have   tesla  coil whit  some  about  300khz  input frek. then  in the secundary coil  yo have  2000 turns  of coil  then  in a ather said  of this secondary coil  make  a anthe  reciver coil   then is hapend  very good thing >>
   you created  300khz  to make  longitudial  wave  ho  provide  to move elktrones  in the 90%  then this wave  is also  product  to make  a sking efeckt  in the  secondary coil   i mean to move onle  elktrones  ho  is  in the surface  in the wire  then  the secondary coli  is making  high voltage  ho is move elktrones  in the  horisontale   if you put  more and more  high voltag  the  elktrones  ho is moving  in the 90%  then this elktrones  is is making  a angle  beter  then 90%  and  you have  movin elktrones in horisontal >>>
now  in the end of  secondary coil   you  can bring  sea of elktrones   ho is  very  compres    then  you put anther coil   ho is  whit  small  turns  in this coil  you have  i high courents  whit  high  frek.   in this coil  you have  a efekt   of sking moving elktrones  ho have able to produced  a cool linght   of  any bulb    .
if you  put bulb you only  you need  1 wire  to produced  the  light  <<i mean  bulb whit folfram  no flurences  bulb .... if you see  i find 1  video clip   whit  some oscilator  whit small  pc batery  and  5 diode  whit  10 cap  blok  like a  ordenery cascade  you  can see there  when this man  is put  a 100 watt folfran bulb  in the 1 wire  this man  is his  hand   is hold  abod  30   or 40 secong  whit   any problem  to hiting of temperature  on his bulb   i that  i told abolt this cool lghting   the bulb is light  so strong  but whit not  temperature  ..
and  if you  put  in this wire  to speed  diode  1 diode in the  mase  1 inthe pluse    then ypu get   a dc out  ho is posible  to created  temperature  or moving force
i make  in the paste   i rf  transmiter   and i find  if you  put  2 diode in the  antena out   then you get  moving force   and if you put bulb in the antena  you get  a light of this bulb   whit  no temperature  in the bulb   athing  that is the mystery  of tpu
<<<created high frek. whit high voltge then make reciver coil  whit small turns  and 2 diode output  then you  get sking moving elktones  <<i mean free elektrones ho able to produced  hi  ampers in the reciver coil
i like to reply  to see what you mean of this
THANKS
MACEDONIA CD
WHAT  YOU THING  OF THAT  ::) ::) ::) ::) ::) ::) ::) ::) ::)
supersam
macedonia,
i think, this an interesting concept, whether it is the same as the tpu, i don't know.  have you done any experimentation in this area?  i would like to see how you measure these forces.
lol
sam
MACEDONIA CD
hi
i thing   if you see  the video  of turbo  i thing  is turbo  nick name is
there  is  bad video  but  is  posible  to light bulb  whit  cool  light
this man  is  send video  and  we   see that  is  real  light whit  skin  moving  elektrones  in the  wolfram  bulb
you see  is 1 oscilator  whit  source  whit  pc 3 volt  batery  this source  is  created  to increase  only  a voltage  then  this  voltage  whit  some  high frek.  is conected  in to a  5 diode  whit 10 cap   << this circuit  is like a  ordenery  cascade   >>  then  this voltage is increse  about  15 time  biger then input  then  this voltage is conected  to  a bifilar coil  whit  10  turns   <<is important  to be  a lints  wire  >>and this coil is generating a longitudial  wave and  is created  horisantal  moving  of sking  elektrones  ho is  in the secondary  coil   and in the end  of this coil is  anther coil  ho is  bifilar coil  in this coil  is out energy   ho is conected the bulb
this divices is  no able to produced termo elktric courent   but if you put  out  speed diode  like a ordenery dc convertor  then you get  termo  and moving force  whit  no diode in the out  you  get only   skin efect moving elektrones   that  isa  reason  way is light  his  wolfram   bulb
you ask  your self  in his video   way  his hand is  not  is burn   <<  beakose  is skin  efekct >> if this  man put a out diode  then  whil get  dc out  but  whit  very small  energy
