Running an internal combustion engine?
Started by Super God, July 22, 2007, 05:01:06 PM
Super God
>9000
IronHead
Super God
:o
It appears I have been tricked!  Then do have to make ANY modifications to the engine?  Wow, this is good news for my wallet.
>9000
IronHead
This is only true as long as there is no KOH entering your engine.You must condence KOH and return it to your Cell or water tank .
Check out High Performance water injection , people been doing it since the 50s
Water injection  helps stop detonation  when running Hi Perf  engines with  superchargers or turbochargers.
Also there is alot of water coming from gasoline in the burn process and from the atmosphere going into the intake .
How much water do you see coming out of a cars tailpipe . Alot most of the time.
I would do the SS valves though as they take heat better at the edge of the valve.
This is the only place you see some heat increases with 100% HHO  everything else runs nice and cool. Also remember there are no carbon buildups with HHO to hold heat and burn away underlying metals . And, the water from the HHO burn or combining process has no minerals in it. It is pure water and you will have no mineral deposits from HHO reaction in your engine.
Water the perfect fuel!
IronHead
Super God
So, would you say it's safe to run an engine on just hho with ss valves?
Alot of people insist on making engine modification, but if it isn't neccessary then to hell with it.
>9000
