Disclosed: Peter Markovich and his 'essential' A.T.R.E.E.
Started by tao, July 25, 2007, 04:56:27 PM
vince
Maybe I'm missing something in understanding the diagram but I only see one layer of wire wound on the primary and one layer on the secondary. That's what I did. It does not state a length of wire only the gauge. I tried to keep the ratio to what was described . I don't understand what you mean by the amp coil. Sorry, but I was only trying to replicate what I saw .
digitalcrypto
Tesla's information described the wavelength he was attempting to capture.
The specs for the wave length from the data I have are 185k miles long, 200 miles wide and 925 hz.
This is a picture of what it should look like in completed stage.  It also has some information which I did not see in this thread.
So check this and let me know your thoughts on it.  You've completed the difficult part.
http://www.geocities.com/capecanaveral/lab/1287/markp6.html
vince
I have never seen that information before. Now I see what you mean about all the wire in the amp coil.  I'm not sure where or if I would get all that wire but maybe I could try using a transformer winding. Just a thought! Getting real late here so Calling it a night for now.
Thanks
Vince
sm0ky2
The rod and sphere must be electrically isolated from one another.
we are talking about a hollow sphere here, not a ball with a hole drilled in it. It must be very thin and smooth inside and out.
The type of metal may vary, but they fall within the class of non-magnetic metals (copper,silver,gold,platinum)
iron or steel will not work, because it induces an opposing magnetic field within the material that cancels out the electric potential.
Be SURE that your wiring is NOT paramagnetic. you can test this by placing a magnet to the wire. If it is attracted, find a different wire. (if you're using copper wiring you dont have to worry about this)
The wires used in the 2 coils should be proportionally sized (meaning that the larger wire is divisible by the diameter of the smaller , or by a common denominator of the two)
Also the number of turns should be proportional to the opposite degree  (2x size = 1/2x the # of turns)
the (inner) coil should be bare copper wire. an insulated copper wire actually has an inductance, which will prevent ANY current from flowing through it. rather we provide a circular (shorted) path for some of the energy to flow through (on the surface of....).  The secondary coil is insulated to created the induction effect to drive the load.
Hope this helps.
[as for the mile long Tesla thing, it's size has no bearing on the effect  Its massive size was designed for one reason and one reason only,
--To Achieve Incedible Ammounts of Energy from One Device - so he could play with it consistently without interupting the commercial power-grid his machines were hooked to. I dont believe he ever got a chance to actually make this large version of the device before his laboratory was confiscated.]
