Disclosed: Peter Markovich and his 'essential' A.T.R.E.E.
Started by tao, July 25, 2007, 04:56:27 PM
Super God
Tao, if you could post a video once you get your device set up, that would be awesome.  Even if this device only puts out enough for an LED, it PROVES that there IS something out there we can tap into.
>9000
vince
For anyone that is interested in this device;
I have made another attempt at replicating the A.T.R.E.E..  This time I took more care at following the description of the device.
5/8 " diameter central core with a tapered tip to needle point. 18" length which is 6 times the diameter of the ball.
Primary coil is 26 gauge copper wire tightly wound onto core with masking tape as an insulator between the wire and the core.  Wire was wound with a jig for a smooth clean profile. Copper wire was soldered at the top and bottom of the rod.
Secondary winding was 14 gauge solid copper insulated wiring also wound with a jig.
3" copper sphere hand formed from light gauge copper sheet. The sphere was not a perfect but I felt that if this device works it should give some kind of reading.
I soldered the wire to the side of the sphere and tested everything for continuity.
I am not getting any kind of voltage at all.  I've tried all kinds of hookups including a ground connection but am coming up with nothing.
The only interesting thing that happened was a reading of up to 35 volts when I touched the sphere with a jumper from my vandergraff generator.
If anyone has any suggestions or ideas it would be appreciated.  I'm not sure this device is worth pursuing at this point!
tao
Quote from: vince on August 07, 2007, 09:23:23 PM
So, the sphere is hollow right?
Can you place a resistor, like a 1 ohm or something, between the end of the rod and the lower end of the secondary wire and measure the voltage across this?
Is the copper rod in contact with the rod at all? At the point where the rod enters the ball?
What is the green piece that is under the copper ball?
mikestocks2006
Hi vince
It's not clear from the picture, but just in case, may I suggest:
The tip of the coper rod to be at about the center of the sphere,
and
the copper rod to not be in direct contact with the sphere.
Nice work, good luck
vince
Ive tried the tip at various locations in the sphere as it is mounted on a plastic insulator that lets me side it up and down.
