Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bruce_TPU
@ Everyone
The newest version of the .PDF is now available for download.  It is located on page one of this thread.  I have completely redone all of it, making it much, much easier to find information by subject.  It is missing the cover, until Dr. Mark returns from his vacation at the end of the month, but I have decided to release it now, for I think it will help everyone out as their build progress'.
@ Bob
Anything in the .PDF you wish to have changed in anyway, simply PM or email me the desired changes, and I will make it happen for the 1.5 future version.
Enjoy!
Bruce
Bob Boyce
@Bruce
I downloaded it, will review it later.
@all
I had a mild setback last night. I had to come into the house to use the restroom and get some water. While in the kitchen I heard a bang out in the shop. When I went out there, I found the toroid on the floor, the secondary winding cut from the impact with the concrete, and my winding spool with the rest of the secondary wire on the floor broken. I don't know how this happened since I had thought I had laid it flat. Upon examination, the secondary and longitudinal windings were damaged in several locations. I was so disappointed that I went to bed.
This morning, I disassembled the toroid and repaired the longitudinal windings. Thank goodness for the beeswax, the longitudinals had just pushed to the side and bunched up. They were not damaged too badly that they needed replacing. I was able to pull the few turns off, straighten, and re-apply. I just finished retaping the core with winding tape. I will not be able to re-use the secondary wire, as I only had half a roll (125') on that spool and that wire was cut too short by the fall. I do not like splices mid-winding, so I will have to get another 250' spool of 16 guage solid silver plated teflon wire. It'll probably be late next week for it to arrive. I sure don't want to have to unwind one of my hydroxy cores (no longitudinal winding) just for the secondary wire unless I have to ;-(
Bob
eldarion
Bob,
While we wait for our cores to arrive (and you wait for your wire to come), would you mind sharing with us how you did the original unstable "golf cart" experiment?  I read somewhere that you took three separate toroidal transformers and hooked up the primaries in a wye, then conected them to some kind of three phase source.  Each toriod's output was then rectified and combined with the other rectified outputs which gave O/U?  I am not sure if I have all of this correct; is there anything missing or wrong?
I scavenged these three identical toroidal transformers from old computer power supplies and would like to put them to good use.  I would like to see if my FPGA-based controller might be able to stabilize the power output (don't worry, I'd always run it with at least a small battery in the loop somewhere in case the controls failed! ;) )
EDIT: As I have had more time to gain a better understanding of this technology, I guess my question should be: how did you manage to get the required interference patterns with three independent transformers? ???
EDIT2: I might have figured this out--I'll build and test it in the next couple of days and see if I'm right! :)  My description above is definitely incomplete!
Thank you,
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Motorcoach1
Bob Boyce
Quote from: btentzer on August 03, 2007, 08:34:50 PM
Hi Bob,
Not a problem, we are a patient bunch.  (Most of the time... ;))  We are all waiting for our cores any way.  I for one would enjoy seeing a picture of your little winding spool that you made.  Also, do you already know how many feet of wire is required for the secondary winding?
Bruce
Somewhere around 90' or so. 131 turns seems to fit well. A bit more turns if no longitudinals are wound underneath.
Here's a shot of the winding spool along with a scrap of the wire with the teflon insulation pulled off.
Bob
