Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bob Boyce
Quote from: Motorcoach1 on August 05, 2007, 01:05:19 AM
Bob i'm not so sure it was a bang . when you wraped the core with the outside windings and the inside wind and added the flat wind on top and bottom. there may be a thing that happens in the passive side. as the natural freq's change you think that the mag lev might have been in tune and when it moved the resonant freq's changed and fell ?  I noticed you shot Pics in front of your monitor and thats a real strong mag feild , if the monitor went to sleep the field would change. I would put the Torriod in the frezzer for a week and if you can get dry ice that would be better, realine the molecular structure in the core before resuming the windings.  self regenaration field ?  when you strike the torriod that will set up a mag field.        @ phase the windings that are diffrent colors in that coil, are the phase condishoners cycle in the winding. I'm not sure why there are 3 coils but it seams that 2 are sufficient the 3ed one might be a control winding when needed in the circut, pulse on pulse off as needed, kind of a twek to the amp levels so it dosen't over drive the curcut.?
No worries mate. That 21" Sun monitor is off when I am working on the bench in front of it. I swept my K-II EMF meter back and forth over the core several times in all directions, and not so much as a tiny blip of magnetic field is showing as present.
It is odd that the core took that dive across the room while I was in the house. It ended up nearly 20 feet away from the bench, behind my lathe stand. I am keeping the shop door always locked now just in case it had some help of the 2 legged variety. That little mishap cost me the use of a 125' spool of hard to afford 16 guage silver plated solid wire, and a couple of days of labor.
Bob
Earl
Beautiful work Bob.  I've heard about torroids on steroids, but I never heard until now about torroids on vitamin C.  ;)
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Bruce_TPU
Quote from: Bob Boyce on August 06, 2007, 05:49:06 AM
Bob
Hey Bob,
That certainly sounded like a 20 foot assisted fall to me.  Unless you have discovered a new form of toroidal propulsion!   ;)
Your coil is looking awesome!  If you have an opportunity to take a picture of your secondary winding tool you described, that would be a great little addition for the .PDF
Great Job!  We are looking very forward to the primary windings.
Bruce
Bob Boyce
Quote from: btentzer on August 06, 2007, 10:05:10 AM
Hey Bob,
Bruce
Yes, I thought that I heard the shop door slam right after the loud bang, but thought I was just hearing things. Since it occured after midnight, wifey was asleep, so nobody was at the helm of the CCTV security system to see if any intruder entered the shop. I had the passive IR motion detector alarm on the CCTV system disabled due to the large number of nocturnal critters that roam this area during the summer months, otherwise I would have heard an alarm sound off.
I already posted a picture of my winding spool, loaded with the wire that I had removed from the 8" hydroxy toroid. That picture is on the end of the last page.
Bob
Earl
Hi All,
after a massive effort and a lot of hours, here is the latest version of my TPU calculator.
Each section separated by continuous colored lines is independent.
You can be playing around with input parameters in different sections for different TPUs.
There is no rhyme nor reason for the input parameters as given.  While I was writing the spreadsheet I just grabbed numbers that fell down from the sky.
My end goal is a stable TPU with air core and n excitation coils, where n could easily be 8, 16, or even 32.  As n increases so should the stability, but the mechanical tolerances decrease so you have to have more precision as n increases.
Please test drive it and let me know what you think.  I have included just about everything including the kitchen sink.
If you find any math errors, please let me know.
Regards, Earl
