Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bruce_TPU
Quote from: Bob Boyce on August 06, 2007, 12:09:32 PM
I already posted a picture of my winding spool, loaded with the wire that I had removed from the 8" hydroxy toroid. That picture is on the end of the last page.
Bob
Thanks Bob,
Somehow, I had missed it.
Bruce
Earl
Hi All,
attached are modified drawings.
Purpose is to have wires referrenced that everyone can refer to.
Second purpose is to show windings a bit clearer.  Mark, when you return, would you please rerender my two drawings to clearly show winding directions.  I removed the twisted windings on purpose to clearly have a reference for each wire end.  One end of all coils is soldered to the metal cylinder and the other ends enter the cylinder through holes.  For example, the cylinder could be at +12VDC and the holes lead to FET drains.
Another example would be to have the cylinder at "ground" and both coil ends are floating and differential, both going through holes into the cylinder electronics.
The blue inner cylinder that I added shows my hypothetical, cylindrical electronics enclosure made from tinned sheet metal.  This provides electrical, and magnetic shielding to a certain extent.
In addition this cylinder is in the "eye of the tornado vortex" and provides equal length wires to both ends of all excitation coils.
Some of you may now see where my thinking is heading to, with rat race of order n.  I don't envision any stuttering or pulse swallowing, only a smooth-running rat race, steady as a Swiss sewing machine.  Then open up a hole for a vortex creation by providing an orthogonal electrostatic or magnetostatic field.  Anyway, that is how my thinking goes today.  Difficult trying to be an aether Engineer since I can't even spell Neanderthalz.  There are hundreds of experiments to try:  counter-rotating excitation, orthogonal electrodynamic excitation of 110/220 VAC 50/60 Hz, etc., etc.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Bob Boyce
@ Earl
Very nice! I wish I had the ability to make drawings like that. About the closest I can get is to just build the device and take pictures as I go. My artistic abilities using the MicroShaft Paint program in windows is limited to rather crude stick drawings. I can't even draw very good looking coils with that.
Yes, I agree, there is much experimentation yet to be done. I spent a lot of time working to improve upon the hydroxy tech, for the benefit of others, while my true interests have always been in direct energy tech. Unfortunately, the research funding for direct energy was just not available, so I had to make do. Thank goodness that at the power supply end of things, they were inter-related, and I was able to sneak in some experimenting here and there in between the hydroxy research projects. The hydroxy research allowed me to build a fairly well equipped shop with some limited machining abilities. Now that the hydroxy projects are largely over and done with, I will have more time to experiment where my true interests are. I would like to explore with adding additional field modulation patterns that may increase the versatility of the power output.
Bob
Grumpy
If you were to power-up a ring underground, say in a basement or cellar, could you expect tha same results as above ground and would it be as safe?
Thanks
        -Frank Edwards
Bob Boyce
Quote from: Grumpy on August 06, 2007, 05:13:46 PM
Thanks
Never tried it, as I don't have a basement.
Bob
