Newman machine with a closed loop selfrunning without batteries or solar panels
Started by hartiberlin, July 26, 2007, 09:40:54 PM
kmarinas86
Quote from: Ray0energy on March 05, 2008, 07:08:59 AM
Quote from: kmarinas86 on December 30, 2007, 03:14:14 AM
Quote from: seekingknowledge on December 22, 2007, 06:04:21 PM
DECEMBER 2007
SPEED IS POWER
Speed is very important in a collision.
If you double the speed of a car,
you increase its force of impact four times.
If you triple the speed, the impact is nine times as great.
Accordingly, the Newman Energy Machine in principle
produces unlimited speed: unlimited power!
Above is the latest addition to the newman website just that no more no less which means no links, wow speed is power we understand what your on about joe lets see some action.
Well ok.  Let's see.
If you keep the resistance held, then power is proportional to current squared.  This is when you keep the same coil, not the same voltage.  If you want to get the most power out of 9V battery, then you use commutators to make the voltage of the wire go up and down as often as possible, because when ever the connection is not there, you are not using the voltage.  So basically, if you want to build more for you money, its best to at least double the number of commutator hits per rotation, and if doing so doubles the current, it will will quadruple the power, while only halving the longevity of the battery, so overall you get twice the energy output.  If instead of increasing the number of commutator touches you connect two 9V in series, keep in mind that the 9V batteries have a resistance of their own, so you won't be able to double the current that way.  Copper wire has resistance measured in ohms per kilometer, whereas a 9V battery may have several ohms.  You would also be eating up the batteries faster that way, not good for longevity.  Believe it or not, if your motor touches the commutator for long, then you are loosing a lot of charge.  There should only be enough to give it the kick.  Therefore I feel that trying to get most out the single battery is a good goal.  After all, a 9V battery costs $4.  And $4 can get you 100 kilowatt hours of electricity, or 43 days worth of nutritional calories.  What we need is a Newman machine that can run on a 9V battery with about 100 watts of output for 43 days.
Actually I have a better idea.  Because we know that resistance of the batteries are much higher than even 1 km of copper wire, we should NOT connect the batteries in series, because that won't change the current.  Not only that, it will waste the rest of the charges!  Instead, we should simply hook the batteries in parallel and have all them run at the same time so that we DO get more current. In fact, I tried this and got better results than when I connected them in series, I now have my Newman machine actually jumping now!
http://www.youtube.com/watch?v=TmIqy-Zk030
stop giving people the impression that u no a lot because u don't u "quote" text  and copy and past.
on your you tube site u delete all comments of people that try to make a debate.
and the most irritant thing is u don't answer but u just go over it wit your long talks of BULLSHIT :( ???
pleas stop this sick madness
The post of mine you quoted above was from December 2007.  This is for the record, I have since learned that I was ignorant about the Newman machine.  I do not put the batteries in parallel anymore.  That is what I thought I was doing when I used the 4-AA battery holder, but that was not the case.  I was so ignorant that I did not know that the 4-AA battery holder I had connected the batteries in series.  But as time moved on, I learned what it really was.  But electronics is a huge subject.
I'll have to quote myself this time:
Quote from: me to ray0energyYou misoverestimated how often I delete other people's comments.  In fact, most of the comments I delete are mine since I later find I have misjudged what the person said, or decided that I could give a  better response.
And please do not refer to giving "thumbs down" to comments as deleting the comments.  They are not the same.  But I must admit that I still acted wrong.  See to it that I do not do this again on these videos.
Ray0energy
Quote from: kmarinas86 on March 12, 2008, 01:17:00 AM
DECEMBER 2007
SPEED IS POWER
Well ok.  Let's see.
i happy to here this from u.
the hole this was that i will never be piste at u if i no that u will not learn something from it.
because for u it is not difficult to write english. for my and many ad ere people like my  it is.
that's way we tray to tel thing wit as less words es possible. u no ;)
and the adder thing is that a lot of this new technology in not in the books as u meeno.
some one like Nicola Tesla he never left a lot of his findings in a well documented books u c.
look i will never try to put u down ok.
i just want u to don't make a fool of your self by writing so mutts.
u can better let the multi meters say it for u like i do.
and if people ask u something just answer as sort as possible.
that make this way of discussion a lot more clear for the rest of the people.
i hoop in the future it will go better and that u find a good dump for same free materials ;)
so u can make a nice copper coil
good luck
ray0energy
springfield
Is there a way I can see this machine for myself? I live in the USA but I am going to Germany this weekend for 2 weeks - short notice but how do I get in touch? Tx
