SMOT Triangular Enclosure Variation, Closed Loop?
Started by jeffc, July 26, 2007, 10:35:31 PM
jeffc
Quote from: amen23 on July 28, 2007, 09:01:38 PM
The SMOT idea works but not the way you planned it........the way you've applied it will never work.1) Your exit for the ball is all wrong. The ball has to exit the forcefield before the tapered end of the row of magnets (about 3/4 of the way,possible more). To exit ,gravity is used (a straight drop out using the mass of your ball against the pull of the magnets) and it has to drop below the force field that surrounds the magnets at the end of the row.(if there isnt enought clearance it will attract)
which means you're faced with a dilemma .....2) your incline should be such that after you ball has broken free from the force field, you got enough energy to return it to to the start. The bigger the incline , the more attraction you need to pull your ball up, the stronger your magnets will need to be, the greater the force field that awaits you at the end. The smaller your ball ......ect ect
you can play around with the size of ball you are using...????
you can play around with the lenght of your rows of magnets ...????
you can even play around withthe strenght of your magnets ...???
;) just my 3 cents worth
@amen23
Hi and thanks for the feedback. I have been worried about the bearing's escape from the end of the magnet series.   Thats the main reason I wanted the have the magnet at (F) to increase the horizontal force.
Don?t you think this will have an impact?
Motorcoach1
 It would seam to put a upwared roll at the D positon at the end of the ramp so the inerta would be equvelent to the speed of the ball and magnetic force of the first permenet magnet to catch and throw to ball to the next PM and so forth till it repetes. thake a strip of sheet metal and try it, roll it at the end with different radiouses. A small radious will slow the ball down and a larger one will speed it up till the inerca is balenced over the curve and magnetic flux feild to the next PM .
HopeForHumanity
Quote from: jeffc on July 29, 2007, 02:00:11 AM
Quote from: HopeForHumanity on July 28, 2007, 04:22:46 PM
What if we tried these ideas, but add zero friction? ???
;D
Zero friction would be very nice.  But, sadly it won't happen!   >:(
But wait, physics doesn't say almost zero friction isn't possible.  :D
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
gyulasun
Hi Jeff,
If you are not very keen on reading German language at this site: http://www.hcrs.at/SMOT.HTM you may use a free online translator like this:
http://www.freetranslation.com/web.asp
On the right (upper) side you can see Free Text Translator Free Web Translator   and by choosing the latter you can copy the Austrian url and choose the translation direction.
Gyula
amen23
hi jeff ........ your point (F) --i dont dismiss the idea and yes it has its merits and might work. However i see a problem with your verticle drop out between (F) and (C).
You will need to gain enough height to drop out of both force fields and still have enough energy to get it back to the start.
I have another theory for you to ponder on .....I'll explain my thoughts on this first.
Any magnet has a force field that will attract a metal object toward its centre . So it stands to reason that a heavier mass will travel past the centre of attraction.(Inertia/mass ect) .  Beyond the centre the mass will run into resistance becos the centre in now behind it and the attraction is now in the opposite direction.
Imagine a falling object from space ... it will be attracted until it reaches the centre of the earth (theoretically) after it pass the centre, its travelling against gravity.
This is the way I think about SMOT .....your ball bearing needs to exit just after the centre of the force field. Its got a great 'run up' and needs to exit before it gets slowed down.
I thought about this a couple of years back and came up with a different approach. Never got round to testing it. I'll try a draw something here ......
        ^   (H)   Using this as a circuit/track
                                          RAMP  ----->   /    --------------------------->
        l------->Start                                  /                                               l
        l          ----   ----   ----   ----   ---- / ---- ---- ---- ----                       l
        l          l PMl   lPMl   l     l   l    l   l     l   l    l l     l l    l l     l                      l
        l          ----   ----   ----   ----   ----    ---  ---- ---- ----                       l
        l        l
Half way through your Smot build a ramp .......let your bearing gain speed -hit the ramp (jump up)and hopefully be elevated to point (H) on you circuit /track let it roll down to the start again. It should hopefully clear the force field ..... dont elevate your SMOT let it gain as much speed as possible. Kinda like a sling shot around the moon idea!
hope you understood that
cheers
don
