SMOT Triangular Enclosure Variation, Closed Loop?
Started by jeffc, July 26, 2007, 10:35:31 PM
jeffc
Hi All, I've been lurking around here at overunity on an off for a few months. Here's a concept of a SMOT variation that I think has some promise.  Please review, along with the PDF docs attached which inclide diagram and walk through of the whole system.
Concept (suggest you look at diagram pdf first):
Combine the magnetic force of a SMOT to create increased gravitational PE which can be used in a way to close the system via triangular enclosure configuration.
IF the magnetic force can be used to drive a bearing up the ?ceiling? of a triangular enclosure, then using a triangular system with an internal ramp could potentially return the bearing to its ?launch? position and enable a closed loop self sustaining system.
Concerns:
Transition points are my biggest concerns, as I guess would be the case with all potential self running devices.  At point (2) as the bearing must transfer from the lowest end of the ramp to the triangular ceiling there must be enough in the combination of remaining kinetic energy from gravity and upward pull of the magnetic force from above to cause the bearing to round the transition point (D).
At point (3) the bearing must have enough energy from the PM series acceleration, with possible assistance from the PM at (F) to not get ?stuck? at the last magnet in the series.  If it can escape the magnetic force from the series, then gravity will take over and the system may indeed be closed and self sustaining.
Disclaimer:
I am not a scientist or an engineer.  Just a tinkerer  who has been interested in overunity since my grandfather shared a concept with me many years ago.
Thanks, jeffc
hartiberlin
Hi Jeff,
great idea,
this has merit, I think.
Maybe you still can merge the 2 PDFs into just one.
All SMOT setups really need very precise mechanical
setups up to 1/10 of a MilliMeter, so to avoid any sticking
it would be also good to use a glas ball just filled
with iron powder as user Epitaxy had used to avoid
the Remanz buildup as it happens in a real iron ball.
Good luck.
Regards, Stefan.
jeffc
Thanks Stefan,
I really appreaciate your work on this site.
I've combined the diagram and description into a single PDF.  Also added a gif version so it will be easier for everyone to get the idea without downloading.
Regards,
jeffc
gyulasun
Hi Jeff,
Thanks for showing this interesting triangle SMOT setup.
If I understand correctly, the ball's own weight is kept also by the attracting magnetic path while moving uphill, right?  If so,  I wonder if this does not make the building of the ramp unnecessarily difficult, for it needs more 'work' from the magnets to hold the weight and move uphill the ball at the same time.
Surely some tinkering is needed but I also like this great idea.
Gyula
Paul-R
You might find the ball rushes up the inside of the ceiling like a
bullet, and crashes into the corner. SMOTs can be energetic.
Remember the gauss gun.
Can your idea be adapted into a circle? Have a gance at this:
http://www.overunity.com/index.php/topic,2745.msg40868.html#msg40868
Paul.
