Eldarion and Bruce's build of Bob's Energy Converter
Started by eldarion, July 27, 2007, 12:58:39 AM
Bruce_TPU
Hi Bob,
Thank you very much for the phase timing diagram.  It cleared up alot of haze.  Nothing like a visual aid to assist.
If I understand what you are saying though, about the "precision phase control", is that every coil will be slightly different, and the phase will need to be tuned from the open ends of each of the primaries, to get the tuning exact or precise, for "that" set of primaries on that coil?
Eldarion and I have decided to go the six primaries route, when we get to that point.  We look forward to seeing the Hex controller you said you did not mind releasing to us.  It should give some good ideas, or provide an "exact" replication for some of the guys who want to do that.  Our cores will be arriving soon, and I for one am very excited to wind a proper coil.
@ Bob and All
I have spent enourmous amounts of time, redoing the .PDF.  Editing it and making it far more professional in appearance as well as much easier to find information based on subject, rather than post.  It will be a couple of weeks before it is ready for everyone.  Dr. Mark is providing some nice artwork and we are adding a cover.  It will also give me time to add the rest of the upcoming photos from the remainder of Bob's build.  I have also removed information not confirmed by Bob, so as not to confuse.  This .PDF will be something Bob can use in the future for any other replicators he chooses to work with.
Also, with Bob's blessing, I desire, when it is finished, to get a copy to Mannix, to get to Steven Mark.  It could be just the thing to encourage the group UEC that controls his tech to also release more information.
Happy Days!  :)
Bruce
Grumpy
If you were UEC, would you release more information?  Would you want people all over the world making their own power and who knows what else?
        -Frank Edwards
eldarion
Quote from: Grumpy on August 02, 2007, 07:12:24 PM
I can smell the lawsuits now! :D
You're probably right...no corporation could ever release this information--they would be sued and driven out of business.
Back on topic, I noticed in Bob's diagram that the frequency mix creates groups of pulses, but that every other group is missing only the third pulse.  I wonder what effect that causes in the TPU?
This also underscores the need for exact 0?, 120?, 240? timing, as without it, those pulse groupings will not be created.
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
eldarion
Bob,
I have one other question for you.  What is the recommended peak amplitude for the three primary frequencies?  For some reason, I was under the impression that it was supposed to be pulsed high voltage, but I was wondering if it might work with as low as 12 volts?
Thanks,
Eldarion
-- Thomas Paine
eldarion
Well, here is the output on the combined test channel of my controller.  We should definitely see some effects here! ;D
Thanks again Bob for the diagram; my pulses looked nothing like this before.
-- Thomas Paine
