Eldarion and Bruce's build of Bob's Energy Converter
Started by eldarion, July 27, 2007, 12:58:39 AM
eldarion
Hey, I thought I would check in and give a brief update.
I now have the second 160V isolated HV supply built.  It does seem to be making a difference (finally!)  With the HV potential in line with the secondary, I am able to use shorter pulse widths to acheive certain brightness levels on the 60W bulb.
Right now, the system is drawing about 4 amps at some voltage less than 11 volts (have not yet had a chance to measure it, but the two inverters go into low-voltage shutdown mode if I increase the pulse width any further--I am still powering the while thing off of a 3A surge 13.8V power supply).  With that input, the bulb is maybe 2/3 of the way lit.  So even if not overunity yet, at least the COP is approaching 1!
To answer Bruce's upcoming question, no, I have not yet engaged the magnetic bias. ;)
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Bruce_TPU
Jdo300
Sounds great Eldarion!
Does varying the HV bias influence the brightness of the bulb?
God Bless,
Jason O
eldarion
Quote from: Jdo300 on November 15, 2007, 07:35:53 PM
God Bless,
Jason O
Hi Jason,
For some reason shutting down the HV power supply (bringing the bias voltage to zero) has absolutely no effect on the bulb brightness.  I may have sounded a false alarm here! ;D
I did try connecting the magnetic bias, and besides exerting a powerful effect on my old CRT monitor, it did nothing.
I am curious as to what Rich did to improve his setup?  My current COP seems to be very close to what he was originally getting (almost, but a little less than, 1).  Speaking of COP, I verified my input power as 41 watts for the approximately 2/3 lit 60W bulb.
I am sooo close, but something is still not right!
Eldarion
EDIT: One other thing: the running converter is generating some pretty powerful magnetic fields--my old CRT gets interesting patterns generated in it when this thing is fired up...
-- Thomas Paine
Bruce_TPU
Hi Eldarion,
Just a couple of quick questions, my friend.
What frequency was your F4 during this experiment?  And did you attempt to increase the frequency to garner more power?  If so, was there an effect?
Did you scope across the "other" longitudinal winding of the core, from the top, bottom, and inside winding on the core, and see ANY signal?  Could you post a scope shot of that for us, please?
Thanks, and great job!  When the magnetic bais affects things AND also the lowering of the HV potential on the secondary affects things, and when those other windings show current, you will have a "fully" working device as described by Bob.  Sooo.... If your cop is at about 1 now, imagine once it is working....!  LOL      ;)
Are you driving the six primaries as two sets of three, or just driving three primaries?  Can you also please post a scope shot of your thin negative pulses off of the primary, since it's fix.  Thanks!!
Side note to all:*Please remember that Rich is using a "pulsed" system, not rotational.  Also, and Rich please correct me if I am wrong, he has no magnetic bias or "other" longitudinal windings on his core.  It is wound simply with a secondary and three primaries.  So, in the rotational mode we should be seeing much more power.  Time to check everything, again.
Warm regards,
Bruce
