single phase power savings
Started by jjbeamish, July 30, 2007, 08:57:24 PM
jjbeamish
For Rving a single phase, not just for power saving but actual RV mode, you need to use ? the rated voltage. Easy to do. I have had single phase 1/3hp 1725rpm 120v motors running on 4watts. (dc to inverter, no power factor). HP rating is less but rpm is slightly faster then rated.
Jason
Thanks,
Jason
Nali2001
Hello Jason,
Can you please explain to me a bit more how you rv-ed a single phase motor?
Thanks in advance
Steven
jjbeamish
Hi Steven,
It?s pretty simple. Use a 4 to 1 trafo, 120vac in and 30vac out. Use a cap bank of 370v oil RUN caps. Put caps after trafo parallel to line and adjust to lowest current draw.
Line in            [transformer]                Cap      cap              Motor
Most small motors I have found have a start winding or capacitor that turns itself off after it is up to speed (centrifugal switch).
You know for sure you have RV effect when you have a higher circulating voltage Amperage between the cap bank and motor then you have watts from a battery to inverter. Also, a magnet vibrates violently 4? away from motor housing.
A single phase can work as alternator as well.
Jason
Thanks,
Jason
ashtweth_nihilisti
Thanks Jason have added that to the compilation.
here is a sch form the latest update.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
jjbeamish
Just use the 1/4 voltage rule per Hector. I would guess you could also re wire it for 120v.
Thanks,
Jason
