Stanley Meyer, please meet Stanislav Avramenko: Water as a fuel...
Started by tao, August 08, 2007, 01:44:36 PM
topsykrett
you could try it if you want but im pretty sure its not gonna do much for you distilled water takes so much power to get the gas out that its not worth it and the rubbers keep burning then you have to put in ceramics and you dont get anything out of it. i hit a single tube with a 1.5 mm gap using a brute force and got just about nothing out of it .i think the only reson they get anything out of the ones in reactors is they use catalyst plates to trigger a reaction . i am familiar with a cavitation heater  but dont know how hot the steam gets
h20power
That is the whole problem you are trying bute force insted of using you brain. Sorry how the came out, but it's the truth. The way Stanley Meyer did it was to use the coils back EMF to break the water down. The transformer that he had is like none on the open market, but some micro waves do use something close. All coil must resonate at the same frequency, the use of different size wire allows for a small step up, say 3:1, but it is the bobbin cavitties that are bumping up the voltage the most. When the magnetic field is cut off all of the Xc's of the bobbin spaces act like a voltage multipliers. Now in pulsing transformers this is normally not a desired effect, but in the way Stanley Meyer used a trasformer it is. The wire sizes I am going too be using to get the job done the right way this time is as follows; .560mm primary, .160mm secondary, and .140mm chokes, all are bifilar wire. I too will be aiming for 42.8k Hz resonance since Dr. John Keely made water seperate at 42.7122k Hz.
The first pic is the way the transformer will look for the most part.
http://s208.photobucket.com/albums/bb249/h20power/?action=view&current=vicforinjectorwithcolor.jpg
also note this is like a showing of all of my work from the begining see the progress I have had and ideas that I came up with.
But note the cone shaped wfc's will work best, I will try it once I get the money to have it machined. It has too do with the properties of capacitance, the smaller the area the smaller the voltage but the greater the magnetic field strength.
Cap-Z-ro
Thanks for taking the time h20...No umbrage taken.
I just try to soak up as much as I can from people like yourself, so any little tidbits are always welcomed from my end...we are all ignorant, but of different things :)
It will be interesting to see what comes from that schematic...excellent looking work btw.
Regards...
HeairBear
If you can get a "Cavitation Water Heater" to work in unity, you wouldn't need to build a Stanley Meyer type device. The steam itself will provide the energy. You could use the steam to run a Stirling engine perhaps. The possibilities are limitless. I wonder if cavitation would work with Freon?
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
h20power
I am now looking into Dr. Daniel Dingel's work to see if I can get this thing done and see an end too the age of oil. His circuit is so much easyer and more effeicent. Still looking up all the stuff, but for now I have went too his delivery system to intorduce hho too the engine, for it is far simpler and acts as a self-regulator in a lot of ways. Both the two Meyer and Dingel are using the same type of Tesla system for the most part so, with luck I will crack this baby soon. :D
I have been learning all I can from every aspect of water. Dr. John Keely's work is very interesting and what an amazing man is all I can say about him.
Green light waves seem to interact with magnetizim that I got from Albert Instine, and is more than likely why Stanley Meyer used it.
I am just like you trying my damedest to kick the petrol habit, and stop all these wars for oil. Looking into Dr. Daniel Dingel's work has gave me some great insight into how all of this works. For it is a dual Tesla resonat tank circuit and the blocking diode is really called a De Q-ing diode too learn more go to these two pages and learn all you can, together we can beat them ;)
http://www.richieburnett.co.uk/dcresist.html
http://www.richieburnett.co.uk/dcreschg.html
Best make a hard copy of them just incase the man takes them down.
