Stanley Meyer, please meet Stanislav Avramenko: Water as a fuel...
Started by tao, August 08, 2007, 01:44:36 PM
Cap-Z-ro
"have been learning all I can from every aspect of water."
In that case you would be remiss if you didn't do a google search on Victor Schauberger...he was/is the man in water research.
Regards...
HeairBear
I bought one of Dr. Stiffler's boards with the AV plug. Very interesting! Stiffler has a video out doing electrolysis with this very board. It was strange seeing almost no current and almost no oxygen bubbles. Does the AV plug require two diodes? Can it still work with just one? Hmmmm.... more tests...
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
forest
Quote from: zerotensor on February 01, 2008, 06:52:31 AM
How this might work:  (pure conjecture, at this point--so be gentle!)
Standing waves of potential are created along the transmission line.  The trick would be to match the wavelength of the standing waves within the water to the plate separation distance. This could be done by tuning the frequency, the load, or both.
Because of your excellent tip my friend, I decided to post my opinion... I didn't tested all this stuff but..
If you analyze Avramenko plug you will probably find that it produces current, effect generated inside semiconductors by a electromagnetic impulse like in case of atomic bomb. CURRENT in produced inside semiconductor, that's how in my opinion Av plug works (unfortunately).
A confirmation will be soon discovered I hope.I saw that Dr Stiffler circuit damaged neon is special way which proof that theory. Current is made "in place" - between two diodes in AV plug.
The proper way to obtain radiant electricity is to match longitudinal waves flowing inside single wire with capacitance of the output load...
THERE IS NO NEED TO USE WATER CAPACITOR OR TWO PLATES!
just use one plate of big surface, match frequency of standing waves (longitudinal displacement current) that way so plate will have a one polarity potential always. If you obtain some potential levels like Meyer described (a few levels which differes in gas production) you will see it probably.
The second problem is  how to rise the potential of this longitudinal wave while flowing over single wire ? Tesla found solution : magnifying transformer, pancake coils !
Now I let you think about it . You can find additional tips in Tesla lectures and looking at Daniel Dingel reactor assembly...
powercat
forest
Yes,maybe I'm wrong about AV plug but the only way is to try to obtain kV in cell and compare output with meyer estimations.
Did you tried to measure current with ANALOG ampmeter while cell is generating gas ?
