3 HP motor works with 116 V and 0.42 Amp. (But don't have enough power)
Started by Mem, August 17, 2007, 05:56:19 AM
Humbugger
Somebody who owns a Kill A Watt might want to stick a nice fat high quality AC-rated capacitor across its power outlet and observe.  If it runs up Watt-hours as if the cap's reactance (1/(2*pi*f*c)) were a resistance then it does not distinguish between VAR-hours and Watt-hours and should not be used to measure energy on the input side of experimental DUT (device under test) AC systems.  It would be okay on the output side, where we have control over the load and we choose a purely resistive load.
I have not been able to find an engineering spec sheet on these ubiquitous units and I don't know what chip they use offhand.
ashtweth_nihilisti
>You might just as well tell me that your two engineers are in the back room converting lead to gold or apples to oranges.
No, all David Kous input and out put still makes your understanding not valid, read the Neon document and deliverance data, conventional theory cannot explain the added gains.
Forget your classic training , we are not stupid and know that reactive power as is, is not  claimed as the OU, i already explained this to you. The Extraction of it is being done and cannot be explained conventionally.
let me put this to you, humbug
YOU- replicate David Kous circuit,  AND YOU PROVE IT DOESN'T WORK
other wise i find i cannot explain any more to you, i would read the engineers results and try the circuits,the lab is the best way for you to educate your self.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
ashtweth_nihilisti
>Yes but it's not necessary at all.  A transformer is not necessary; a simple bridge rectifier and very large filter cap will do.  DC measurements are not prone to the misunderstandings and measurement errors due to phase shift and power factor, but the output side measurement really doesn't need nearly that much attention!
this is different via RV theory, it depends if you are using Hectors method of extraction where we use the RF nodes,  and a transformer is needed/used (Trafo in the comps)
I suggest you Both read these compilations to save allot of re explaining how RV works, and how the extraction process is done
http://www.panacea-bocaf.org/files/Advanced%20RV%20Research%20and%20development.pdf
http://panacea-bocaf.org/files/RE-OU-v6_1.pdf
Humbugger
Ash-
read both of those thoroughy.  extremely unintelligible to me.  sorry!  i tried but it's not making any sense to this old conventional electronics design engineer.
i guess i just live in an entirely different world than those of you who really seem to understand this stuff.  the technical jargon is totally foreign to me and there are many statements that appear to be frankly inaccurate or entirely nonsensical.
no hard feelings, i hope!
cheers, and have fun visiting with Charles!
Humbugger
ashtweth_nihilisti
Hum, It has been [reported]  done so far by three. Brian prater reported self running a RV lawn mower, he got spooked and disappeared with it.
Hector, he also said he got interference when he disclosed a looping set up.
David Kou so far is the only person disclosing an EASY method to extract the resonance.
Dont worry , conventional theory wont help, David Kou has stated that he cannot explain i via conventional theory.
Hum  since you are so much value here and thorough, i will Send you a kit of the circuit, we are making 4.
Only thing is if its used for your OU prize, please donate it back to Stefan to help the forum. I wish more people would replicate David Kous information.
