Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
LtBolo
@ esarouho (and R)
Excellent news on the meter! I really wanted that to be the case...but feared it wasn't. Thanks for the confirmation!
@ Ash
Have you noticed any increase in the cell's impedance while conditioning? If so, it should manifest as increasing voltage to maintain the same current.
In other news:
Messed a bit more with the heavily oxidized aluminum tubing...high voltage, indeed...but virtually useless for gas production. Makes pretty sparks at about 200 volts though. It was worth trying, but I don't think aluminum is a good choice.
Still wondering about the effect of nickel content...nickel oxide in particular. Mills work seems to center around nickel (with special references to nickel oxide) and potassium carbonate. We ran one of our cells in reverse for a while and noted that we got a gray/black powder sticking to the calcium coating...which since reversed, was on the outside of the outside tube...made for easy viewing. Nickel oxide is dark gray, so it seems likely that is what the black stuff is. Over 3 months, you might end up with a high enough concentration of nickel oxide mixed in with the calcium layer to become catalytic.
Also wonder about the potential for the cell to gather potassium over time. Pretty much all water has some. If it were to precipitate out over time, the concentrations might get high enough to be useful. That does seem like a stretch though.
I'm really not obsessive about Mills and Blacklight...it is just one more theory that has some merit and possible application. We don't need a theory to experiment...but we need to use the experiments to develop a theory. Without a theory, this process will remain slow and difficult.
Our plating equipment came late in the week. We hope to nickel plate some tubes and then oxidize them.
ashtweth_nihilisti
I already told you that the efficiency increased with conditioning (gas flow test) , many have already proved this on video
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
insane4evr
Quote from: LtBolo on August 18, 2008, 12:08:41 AM
..... Nickel oxide is dark gray, so it seems likely that is what the black stuff is. Over 3 months, you might end up with a high enough concentration of nickel oxide mixed in with the calcium layer to become catalytic.
So that is what it is. And I thought my setup was contaminated and was sanding them off my cathode plates. .duh
Thanks for the enlightenment.
LtBolo
@ Ash
I asked about the cell's impedance as indicated by increasing waveform voltage across the cell. I didn't ask about efficiency.
xbox hacker
Hey everyone....someone asked to see my gear...so here it is  ;D
Dave Lawton PWM
100turn Bifilar coil
