Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
dutchy1966
Hi everyone,
Seeing as ther is such a big difference in the price between seamless and welded 316L tubing, can anyone explain why it is better to have seamless tubing?
For a first test rig can we not use 316L welded tube?
thanks.
Robert
saintpoida
im just guessing but i would say its because of the smoothness inside/outside the seamless tube as there is no weld bead or whatever
but i dont actually know im just guessing lol
if i am right you can probably use a welded one anyway just make the gap bigger between the tubes
so no arcing can occur where the weld bead is??
dutchy1966
Quote from: saintpoida on September 05, 2007, 05:30:30 AM
Hmm, you might be right. I just presumed they would remove the excess bead after welding, but maybe not....
Robert
saintpoida
yeah beats me
Quote from: saintpoida on September 04, 2007, 07:56:02 PM
looks cool!!
i have been trying to look up and research bifilar winding for past couple days now and most of them that i see
are wound with 2 wires and have the 2 wires connected together at one end, but when looking at
stans stuff and d14 it looks more as if the 2 wires are wound together but then one is used for positive and one
is used for negative
so in simple terms when you bifilar wind the coil will you have 4 wires coming out of it or 2?
is this correct? or am i reading the diagram incorrectly? (cause they sit so close together)
anyone know the answer to the above quoted question?
dutchy1966
Quote from: saintpoida on September 05, 2007, 06:02:30 AM
yeah beats me
looks cool!!
You will have four wires coming out (2 on each side). How you connect those wires together depends on your specific situation. In the Stan Meyer case it seems like the pulse sent down one strand will be blocked by the induction in the other strand. (and therefore reduce current flow further)
Robert
