Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
RunningBare
Which begs the question, where are the other replicators?, I've seen a few who have Ravi's tube setup, but non of them have stated they have the same results as Ravi.
My setup was only to test the difference between straight DC and pulsed DC on electrolysis and I'm sorry to say but so far all I see is a loss in the latter, but if you folk really want to get serious about this, forget the blather about resonating the tubes!, but look at the series resonance instead, the tubes will NOT physically resonate, if you do not believe me, try putting a sensor on the WFC, if there was any physical resonance it would show up on a scope, about the only thing that will show on the scope is the noise of the bubbles.
Sorry guys, but I'm a realists, I do not go for this energy from the resonant heavens  ;)
Quote from: motofox on September 30, 2007, 08:48:04 AM
How many people have to replicate somthing before people believe it works?  If runningbares tubes were the same spec as ravis, then i believe he too would have a ravi replication..
dutchy1966
Quote from: RunningBare on September 30, 2007, 09:02:43 AM
Well said runningbare! There is no physical resonance of any importance. If people would only read what Stanley wrote in the tech brief...everything you need is in there.
Btw I'm waiting for the acrylic tube to arrive, have SS tubes ready, pulser build.....
Robert
peter from oz
Hello Runningbare, l cant get carried away with something l dont understand, but please presume l really want to get serious about this, what do you mean by look at series resonance, what changes to what would l have to do for what outcome. l have the D14 curcuit without chokes and 7 tube cell, slightly conditioned ???
Peter
RunningBare
Sure, this is a series resonant circuit
Now just think of that 10uf capacitor as the tubes and another coil on the other side, either way it is a series resonant circuit, at the resonant frequency this circuit would have lowest impedance(resistance) to current flow.
ETA, it should be noted that this is not beginner electronics, the formulas for calculating parallel or series resonant circuits can be quite involved, below is an example formula for series resonant
With the total series impedance equal to 0 Ω at the resonant frequency of 159.155 Hz, the result is a short circuit across the AC power source at resonance. In the circuit drawn above, this would not be good. I'll add a small resistor (Figure below) in series along with the capacitor and the inductor to keep the maximum circuit current somewhat limited, and perform another SPICE analysis over the same range of frequencies
Quote from: peter from oz on September 30, 2007, 09:35:15 AM
Peter
