Rotational PMM by wizkycho
Started by wizkycho, June 05, 2005, 02:32:26 PM
wizkycho
http://starglider.netfirms.com/RPMMonly.html
both linear and rotational motors works
read carefully.
it is logical to reason (only first look) that two magnets will attract shield two times as hard as one magnet. even in that situation
2* Emag(left side) - 1* Emag(right side)= 1* Emag AT THE SHAFT (INPUT ENERGY).
This means i need exactly ammount of energy to overcome ONE magnet at the input.
As a result of invested energy (shielding removed) I get 2 * Repulsion Emag at the OUTPUT (piston).
therefore my device operates at COP=2 - some friction => COP=1.8 which is still FE
You all (i'm little dissapointed) overlooked one property of permeable materials it is satturation (of shielding)
If shield is satturated to maximum it will "REPEL" !?! (bounce) from magnet to the place on magnet where is less satturated and field density is lower. You don't believe this see this very simple experiment I assure You that this is not happening cause of induced current in permeable object.
the experiment: http://www.geocities.com/wizkycho/index_files/magexp.avi
back to linear:
So if one magnet is sufficient to satturate shield (with respect to its thickness) to it's satturation knee there is no place for additional magnetic field from the other magnet niether to attract nor to repel that shielding.
Callibration doesn't have to be that precise and can be done by 0.5mm gradient (for thickness of shield).
in worst case (unsuitably thick steel) you'll get? 2:1 for OUTPUT Yeah !
if you experiment with different thickness of shield you are in 7:1 range
I think with this we have depleted all open questions for linear motor
What Ya think 'bout Rotational.... cmon I dare you . I think it is very very powerfull
there is an error in COP estimation. It is well beyond 14.
Cmon Brainstormers
m668004
@wizkycho
I think I understood. The permeable rotor is already saturated by the statormagnets before to rotor with the magnets is inserted. So when the permeable steel is moved the rotormagnets move not because they are attracted to the steel (they can't, its saturated) but they moved only because they were repelled by the outer magnets when they are not longer covered by the steel.
Maybe the rotormagnets will begin to swing between the two repelling zones at the ends of the steel covered zone if the repellation is to strong. What do you think?
M.
wizkycho
Quote from: m668004 on June 05, 2005, 03:08:11 PM
@wizkycho
M.
if you are refering to rotational design:
why would it swing, does it have AC current applied somewhere or the shaft is frictionless!?!
1.there is shielding and no matter how inprecise you make it will represent "walley" of mag field strenght so rotor will rest where this "walley"(lowest repel) is.
2.You can make better (thicker shielding) that just very slightly attracts Output rotor magnets, so the walley becomes
abbys and Output rotor shurely must go and stay where that shielding is.
3. Please observe that this shielding is U (fliped hor.) shaped so both NORTH vectors (from Output rotor magnets and ring mags.) goes to attractional SOUTH (on ring mags.) through that U (fliped hor.) shield
SO THE SHIELD CAN BE VERY THIN AND STILL SECURING ABBYS FOR OUTPUT ROTOR MAGNET TO REST THERE.(if shielding is resting)
No swinging sorry !
THIS STILL WORKS VERY VERY GOOD, COME AND STOP IT.
Next...
ooandioo
Here is whats going to happen.
The inner rotor (magnet) will follow the outer rotor (permeable steel) with exactly motion.
The inner rotor is repelled on both sides with same F - so it will do nothing. After mounting the shield it will head it, because 1. its magnets are attracted by the steel or 2. the steel provides the only "magnetic free area" in this circle.
As the shield is moved the magnets will follow it.
-- Andi.
m668004
Perhaps we can generate electricity directly with the movable shielding, when we replace the inner magnetic rotor by a coil, a toroidal coil in this case. The magnets and the coil are static, only the shielding moves, so a periodicly changing magnetic field is created and a current in the coil is induced - without moving the magnets or the coil! The big question is now: will the rotation of the shielding slowed down by lenz-law?
M.
