Rotational PMM by wizkycho
Started by wizkycho, June 05, 2005, 02:32:26 PM
wizkycho
Quote from: ooandioo on June 05, 2005, 04:28:19 PM
Here is whats going to happen.
The inner rotor (magnet) will follow the outer rotor (permeable steel) with exactly motion.
The inner rotor is repelled on both sides with same F - so it will do nothing. After mounting the shield it will head it, because 1. its magnets are attracted by the steel or 2. the steel provides the only "magnetic free area" in this circle.
As the shield is moved the magnets will follow it.
-- Andi.
I won't answer to this but I can say (scince you start GUESSING) that You are very very far or to fast in undrstanding
magnet phisycs.
Please Correct Yourself.
Maybe You want slower animation !?!
Once Again
Green(with brown) - input rotator (little enrgy only for friction)
Yellow - output rotator capable of Full repel action (if under max load - why wouldn't it be)
Magnet at outer rotator just MUST (high energy output) follow shield (little energy input)
is it so hard to see. Cmon people there are only TWO ROTORS.
Look again
wizkycho
Quote from: m668004 on June 05, 2005, 04:54:07 PM
Perhaps we can generate electricity directly with the movable shielding, when we replace the inner magnetic rotor by a coil, a toroidal coil in this case. The magnets and the coil are static, only the shielding moves, so a periodicly changing magnetic field is created and a current in the coil is induced - without moving the magnets or the coil! The big question is now: will the rotation of the shielding slowed down by lenz-law?
M.
scince there is now relevant change in field of the shield you induce very little or nothing.
sorry !
Am I right ?
m668004
@wizkycho
@ooandioo
I think its important for wizkychos device, that the magnetic rotor is under load, so it resists an easy moving. If under these circumstances the shielding moves, than the magnetic rotor will and must follow with the same speed and more energy output than input is arrived.
M.
ooandioo
Quote from: wizkycho on June 05, 2005, 05:14:25 PM
-- Andi.
magnet phisycs.
Once Again
Look again
Sure - i understand the system. I only explained it in my words to help understand...
In my opinion, thats an idea worth spending time for. Any more details for building it? Are you going to build it?
-- Andi
wizkycho
Quote from: ooandioo on June 05, 2005, 05:34:42 PM
-- Andi.
magnet phisycs.
Once Again
Look again
-- Andi
well I didn't mean to be rude. but I got impression that you thought about this design with only 1% of your barin.
You all must Know that there has not been more powerfull OU device based on permanent magnets that surely works
than this one.
