Rotational PMM by wizkycho
Started by wizkycho, June 05, 2005, 02:32:26 PM
HardNor
Hey guys - i was reading the whole thread just now - i found the idea great, iam thinking since some days about over unity machine. My idea was similar to the "Takahashi-engine" but your plan looks much better. - i was wondering, if the bigger size ring magnets are too expensive why you dont buy manny smaller ones - and arrange them like one big ring. Keep going, great idea!
ooandioo
Thanks for the suggestions. A completely closed ring magnet would deliver a closed flux system and so the force that appeares between Shield and inner magnets would be same at every postition.
But you are also right, if the input rotor with shield would me moved at continous and specific rpm, the different forces could be ignored...
-- Andi
Light
"This is the completely true analogy".
- Maybe. If you put an additional source of energy to run a "shield" in Kalinin's motor, yes you'll get "diesel" like principle. And with system of "compensators" the positive balance can be achieved.
But in your scheme you just "bend" fields in shielded space, and forces in total going be equal. The outer rotor will follow running shield, i.e. will depend of how powerful drive of inner rotor is. You should  brake and  close a field some how with a smaller force to actuate the clean power of magnets. And then, yes, limit just a sky...
wizkycho
Currently I'm working and allmost finished preparing very interesting and promising experiment.
Electrolysis of water with AC variabile square freq. generator in order to be able to find resonant frequency of
"cell with water" itself. In that point current for generating H2 + O2 mixture gas shuold drop to very small currents.
Some reports say that COP 7 to 11 can be reached with such approach.
when experimenting starts you'll be informed in elektrolysis topics.
This is the only reason I currently pause on making Knitels RPMM.
ooandioo
Ok. Currently I'm doing some tests with shielding. I will keep you informed.
The best would be, to test the whole idea in a 3D Software. Do you know any good one (perhaps free like femm)?
-- Andi
