Parts list d14
Started by saintpoida, August 28, 2007, 06:22:16 AM
keithturtle
Ya won't need everything on the list, 'specially the chip resistors (I don't know much, either) jes check against Dave's parts list.  The MOSFETS are comparable, but once you get to Mouser.com y'all can pick cheaper ones.
Turtle
Soli Deo Gloria
saintpoida
ok went to shops think i got most of it but a few things i need to check
1.) The mF for the capacitors does that translate directly to uF?? From the guy at
the store it generally does?
2.) The black ring on a diode does that directly translate to the black line in the circuit
diagram? (So i can get it around the right way) Im guessing it does?
3.) The four pole 3 way switches, my four poles are all in the middle, the drawing
has 3 poles on top 1 in middle, does it matter which way i wire this up? Or does
it translate that pole D is the middle pole or something?
4.) The inductors, how do i got about winding them? What technique do i use etc?
Thanks again
keithturtle
SaintP;
1- usually.
2- I think so, the triangle points same as current flow.
3- It matters a great deal.  Use Ohmmeter or continuity check to follow the schematic.
4-Buy 'em if you can.   I built a winder but ain't used it yet, still not quite done.  Two keys in winding... keep wire tight, and even layers.   Might use thick CA glue at the end of each row then after it sets, start back the other direction.   Thaere a lot to it.   Spend some time researching it.   Otherpower.com has much on it.
Turtle
Soli Deo Gloria
saintpoida
Thanks turtle,
Also withh bridges i am just using normal wire thats fine isnt it
keithturtle
Make sure it's heavy enough gage to carry max amp loads.
I never load a bridge at rating for more than a few seconds, and have a heat sink bolted to it.  Run a fan if ye git a big rise in temp.
Turtle
Soli Deo Gloria
