Interesting train of thought - magnetic transmision
Started by armagdn03, September 04, 2007, 01:21:01 PM
armagdn03
http://amasci.com/elect/mcoils.html
An interesting train of thought. Definitly worth a look. No immediate applications come to mind, as I am more knowlegable in electrostatic technology rather than magnetics, but im sure this could be put to good use somewhere, expecially the magnetic saturation switch for turning "off" an electromagnet or the transmision of magnetism with an absence of electron movement.
I wish I could turn my brain off sometimes, then I could get some sleep.
pese
Quote from: armagdn03 on September 04, 2007, 01:21:01 PM
@all.
it is NOTHING to do with them.,
I think , the autor must know it .
Very easy to understand that .
most is not to use
also #13 to 15 is WRONG
pese
www.pese.cjb.net
pese
[/quotMagnet
http://amasci.com/elect/mcoils.html          Transformers          RIGHT ANGLE CIRCUITRY
What the autor not know... You find with me  G.P
Pic#8 ..
the magnetic induction , will only flow around the rigth side from left core and
never transfers the left side of the right sided transformer , so he can not magnetized
some induction from #1 to #2
Pic #9
Voltage cant couple capacitivly out.
even if voltage is hight. . IF capacitance is in picoFarad Range , and the Frequeny is in RF
Range  (short wave , FM enz) then is it possible , but no iron-core  transformer is needed.
But anyway , an "wire" i better solution.
Pic#10
Is not strange . you can use  even 10 transformers   in serie (each-one produced also losses.
Pic#11 & 12
Yes this is true
Pic#13
No , this is wrong
No permanent (or DC ElectroMagnet can disconnect the magnetic  AC Flux totally , because
an AC Magnetfield flow "anyway" from coil #1 to #2
Pic#14
No ,it will not give higher voltage  out
Pic#15
Nothing will be magnetized , such way
With an AC Electromagnet (3.coil) you can , amplifly or  degrease the power , also set to Zero (an #2)
BUT : you must "pump" aditionally  power into an 3. coil
Pese
