Wow! Floatation machine!
Started by psychopath, September 07, 2007, 07:34:50 AM
psychopath
http://www.youtube.com/watch?v=gxnHJoyrQpM&mode=related&search=
For some reason I am sort of puzzled at how it goes up the pipe, but it seems to work!
ps it is not perpetual or overunity, but I am still amazed for some reason.
edit:Sorry, I have put it in the wrong section...
tinu
Not only it is posted in the wrong section but it was already discussed elsewhere.
The movie is showing nothing more than a rare piece of marvelous completely useless machine.
Not surprisingly, it is coming from Mr. Tseung. Now I can understand better some of his hidden reasons and agenda: if spending several good thousands dollars on machines like this (and on various auxiliary equipments as well as on rent, energy, wages etc) then it is not surprisingly your financiers will not be happy at all. In extremis, promoting to the absurd may offer a little bit of excuse and may buy some time before the final judgment?
About the machine itself: one phase of its cycle was carefully removed by editing the video. The phase in which the orange weight is removed from the tube at the upper part. Why? Because when removing the said weight, one can clearly see that the water level in the tube dropped. What would be the energy to raise the water level in the tube after removing the weight? More than that extracted!
You ask why is the orange weight going up to the tube? That?s a simple question: because its density is slightly lower than that of water. In other words, the weight is floating, nothing more than that.
It is too bad that some funds (and quite important for small labs) go into holes like this.
Funds that otherwise could be used for real OU research and experiments!
Or maybe for other important areas like health and medication, right Mr. Tseung?
(I can?t help but noticing the great resemblance of that orange weight and a pill. A huge pill!  ;D)
Have a nice day,
Tinu
gaby de wilde
Quote from: tinu on September 07, 2007, 09:41:32 AMit is not surprisingly your financiers will not be happy at all. In extremis, promoting to the absurd may offer a little bit of excuse and may buy some time before the final judgment?
Ow yes those poor bankers again, eeeew must have mercy on the bankers!! ROFL!! You seem to think an investor is not capible of making up his own mind, and you seem to think his money is yours to direct? Did you notice you are quite insulting? Why is that? Cant you use normal words?
QuoteAbout the machine itself: one phase of its cycle was carefully removed by editing the video.
No this was absolutely discussed, you can ask Lawrence anything about it YOU LIAR.
QuoteThe phase in which the orange weight is removed from the tube at the upper part. Why?
Because that was not part of the setup. DOHH!!
QuoteBecause when removing the said weight,
By talking sad bunk?
Quoteone can clearly see that the water level in the tube dropped. What would be the energy to raise the water level in the tube after removing the weight? More than that extracted!
YES!!! But you sure can use it to generate power from small mountain steams. And you think you can blame some one for researching something and sharing something.
What have you researched? What have you shared? Nothing? Show me one of your videos.
Then we can compare you.
You have nothing to show? Your sharing involves just complaints? How are you going to build something that works with this approach?
blog  | papers | tech | inventors  | video
argona369
Your absolutely right Tinu.
The top of the water tube is sealed and there?s
absolutely positively and conclusively no way to
remove that orange pill without lowering the water level.
There?s absolutely NOTHING remarkable with that demonstration.
Added: actually the water level is already lowered when the ?pill?
reaches the top.
Energy is needed to replace the water to the top.
nothing remarkable.
tinu
@ gaby de wilde
I?m still waiting for your reply in the http://www.overunity.com/index.php?topic=2794.255;topicseen thread ?
Discussion is there, not here.
I stopped asking Lawrence questions some time ago because if you check the above thread, it is clear that he is answering neither to me nor to anyone else having a real issue.
Now, you have to calm down, not me.
The visitors Mr. Tseung will bring to you on your forum will not be significant, neither in quantity nor in quality. So rest assured; you loose nothing. If you want to defend Mr. Tseung just for a little service (I?d rather call it disservice, but it is not my business) he is doing to you, that?s understable also.
Anyway, if there is something serious to discuss, post your answer in reply to my post to you and discuss real subjects for why we are here.
My position to Mr. Tseung is derived from existing posts, from our previous ?dialogue? and from his un-realistic claims. I?m against him and there is no secret in it. Does it offend you? Hmmm?
I?m fighting against false claims and I cure the disease with surgery, if needed. I was against Bill Mehess, onegift4power, innovation_station and others, just to mention a few. I am against Tseung also and I will be against everyone plaguing the field, including you if you will not be capable of admitting you were wrong?
That?s why you agitate?
If I research something or not, why do you bother? Is it a prerequisite to be a member here? I don?t think so. However, if you want to check what I experimented and what I do experiment for now and what I will experiment, check my posts, before everything else.
I?m not a liar and I do not do videos.
Something else I can do for you, Sir?
Have a calm day,
Tinu
PS. Tx, argona369!
