So Wheres The Power Then ?
Started by b0rg13, September 11, 2007, 02:38:00 AM
shruggedatlas
Quote from: b0rg13 on September 11, 2007, 02:38:00 AM
with all the stuff inve been reading in the forums here power seems to be all over the place...but where is a real working system....there seems to be lots of partly made systems... is any one able to post real working systems?....is it not possable to simply hook up a motor of some kind to a generator of some kind ?..or am i missing the point here?.....surely there are working ideas out here, cant we get a list, most of the forums seem to start off really well, then it seems to turn into bitching ::)
Ask Lawrence Tseung and he will gladly tell you about the devices he presented in China at Tsing Hua University.
And think of electricity like a pipe of water.  There are two factors - width of the pipe and the water pressure.  Volts are like pressure, so it is easy to adjust pressure, like putting your thumb at the hose tip, but this does not affect the amount of water coming out.  You could have very high pressure but a very tiny amount of water.
lltfdaniel1
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
b0rg13
Quote from: crazyman on September 11, 2007, 09:41:57 AM
Forget about quantum fluctuations, vacuum fluctuations, virtual matter,
zero point energy, casimir force, quantum tunneling.
All you need is a concrete flywheel! You pulse the output so the flywheel
doesn?t see the load!
Or just hook a motor to a generator! Or a battery to a battery charger to
charge itself!
If that?s not your cup of tea then perhaps billiard balls and a wheel!
Just put 7 on one side and 8 on the other! Simple as Pi!
Waahaaahaaheeeheeeheeeheee
(running around in circles waving arms in the air).
hmmm so a concrete fly wheeel hooked up to a generator...use some of that power to pulse a couple magnets in the fly wheel ?..as in a pulse motor like i see on the forums here?....
does running around in circles waving arms in the air work |?, i never thought of that!.
if you want to get out of the rat race,you have to let go of the cheese.
crazyman
Yes! Forget about real OU research!
Waste your time building concrete flywheels with magnets!
We can beat gravity with THAT!
WooOoooOooo,,,,,, (flapping arms, eyes twitching)
crazyman
You know b0rg13 ,
I used to be sane!  keeeeck keeeck, (contorted neck twitching).
Then I came here! Weeeeeeeeee! ,,,,,,
Things  like resolving the link between gravity and electromagnetism,
(though electromagnetism is perpendicular to effect),
or that electrostatic field lines are square root and identical to gravity (aspen),
(though electrostatic field lines are polarized and gravity is not)!
Are being solved here through flywheels, billiard ball, hammers and reflected power in motors! Weeeeeeeee,,,
That Faraday showed that bismuth opposes a magnetic field, though particles
in the bismuth aligns s-n-s-n-s-n and do not set up a n-n, s-s null within the bismuth material!
That gravity can bend the path of light and electromagnetism can only rotate it!
That Faraday through electromagnetism could rotate light inside a helix coil but not outside
of it! even if the test material was touching the coil!
WoooooWeeeeeehaaaaaaaaaaaa,,,,,,
Keeeck keeeck keeeeck, WoooOooooOooooOooo
(pecking at bird seed spread out on floor)
