ER1200 water torch
Started by Prophmaji, September 12, 2007, 09:55:07 PM
Prophmaji
If you do a google or youtube search, you should find the official tape of the government test, in Canada, of HHO gas and a torch being used to lower the radiation count of a given piece of radioactive material. No need to re-create the experiment. Suffice it to say, that the HHO does that and more. I'm well satisfied that it can be used to do some quite interesting things. I've got enough going on in my life right now, that I'm not too interested in controversy, or..attention from that particular crew. Sadly, this would drastically reduce the current worries over nuclear energy use, in terms of dealing with the effluent from such energy production. However, the solution opens more mystery boxes than problems it solves.I keep thinking that the utter lack of energy research is down to a few things. -Change is coming so fast now, that any solution implemented is hoplessly outdated by the time it is actually 'on-line' as a working solution. I'm speaking about energy crisis and any 'solution' that is not 'over unity' as we like to call it. Things are changing far too fast. All human knowledge is changing so fast that the amount technical data in existence is doubling every two years. This pace will only increase. differing groups are holding back and awaiting this new 'change'. Humanity is moving too fast right now to even implement any change for the overall group.Ã,  Due to this and other things...it is very likely that the internet will rule the 'change in man', that is coming.
Back to the subject at hand. for example, look in the picture. The materials have nearly re-combined back to their original masses. The glassy substances have aggregated, and the copper has re-aggregated. They were throroughly mixed with about 10% silica, or 'firebrick' which is obviously not a pure silicate. Nevertheless, the experiment shows intersting results.Ã,  Remember, I have access to about 1600L per hour, so I have little difficulty in creating and sustaining interesting effects.
One trick, is to get a very strong clear column, and then immerse one end in water, then, fill the tube with HHO. ignite. Watch the HHO collapse..and the vacuum will fill the pipe with water. then do an efficency test on what it took to raise the water column height. Archemedian vacuum, anyone?Ã, Ã,  :P
Sebaw:
Yes, that is copper and glass. Or, more properly, copper and firebrick. Slightly higher levels of glassy material, ie pure quartz added to the mix, to the tune of about 20%, is considerably more bizzare looking. Near complete crystalization. The upper black layer is ridiculously hard. I had to press quite hard with a CR-V screwdriver to impress anything into it at all. It took such a serious swing with my screwdriver to split the chunk..that I cut a notable dent into the countertop with the tip of the screwdriver. Note the crystallization of the copper. It is at about 100k-60k ohms of resistance, on average, across any given half inch span.
Prophmaji
I just did a check on my little pile of samples and that one in the picture is more like 30% or just over of silicate mixed into the copper. It's a true glassy copper or amorphous-semiconductive copper. The pinkish part is, of course, the copper component. I again stress that it was not left to sit on it's own, I was actively attempting to move it about with the flame, to mix it with the firebrick material. I was successful. This is the outcome. I've done identical things to CR-V tool steel. Not as interesting as the copper, granted, but interesting nonetheless. I've attempted to heat teflon, which pops like firecrackers.
It should be obvious by this point, that a massive amount of alloy work will appear out of people utilizing this gas's actions upon substances, as well as complete understandings of what exactly goes on in molecular level work in this area of alloy work, and the like. Until now, all they do is throw some crap at the fridge..and see if it sticks. If it does, they try and patent the method.Ã,  This is largely more of the same, but on an entirely different level.
I ran into one of the 'spooks' whom had enquired of my activites a while back. He and I had a discussion on the pace of technology change. And most specifically, how fast the landscape is changing, in terms of how many people are aware of the realities of such and how many people are interested in 'zero point' and the other names it may go under. He and I both agreed that the capacity for the 'powers that be' to slow such down is rapidly diminishing. The problem being, the exact point I hypothesized to exist (now) over 15 years ago: the pace has accellerated, and the egress of information is too great, too much, too many people. The time of the supression and control is ending, due to too many different technologies emerging all at once, from every corner, from every area of endeavor. Far beyond that which is in any way possible to deny or to control. I told him that 'carbon nanotubes' of a superconducting nature, are available, on the internet. $100US, for 5 grams. He said, "Let me guess..from China?" I said, "No, from about 20 different places in the US." "Oh", he said, "That means we are speeding toward a dead end." (end of world). I asked him to not be so fatalistic.Ã,  That's the problem with some folks. Too fatalistic and too negative to trust in the human race. He should understand that there is little choice in the matter. It's coming anyway. However, like the cold war ending, one must be aware that the change brings about it's greatest dangers at that point. The stress levels and breaking points are quite high....and near.
ChileanOne
Hello Proph:
I am more and more amazed by your comments. Surely the HHO is not receiving the attention it deserves.
I agree completely with you about the "avalanche" of information that is quickly bringing the paradign shift, we live now in a perpetual change status that is only accelerating. The process seems to be harsh for most people, but I also believe that at the end awaits to mankind a golden era. Let's see. I for one, am optimistic pesimist (it's going to hurt, but at the end we will al laugh hard and long).
Prophmaji
I would also like to add that the creation of pure, small glass-like (ruby like) granules in the mix means that this can be used to create quite inexpensive industrial diamonds, for example. They'll likely be better than all other industrial diamonds, in terms of quality.Ã,  Once again, the HHO 'flame' can be used to do just about anything you might imagine, when it comes to glassy alloys. of any kind. Heck, bismuth glass, for example.Ã,  Anything can be combined with just about anything. I once did a weld into firebrick, of a three pionted meld of brass, aluminum and copper brazing rods. All bonded together into the same spot.
ChileanOne
Dear Prophmagi:
What you recount points clearly to atomic level phenomena being promoted by the HHO gas.
