Circuit setups for pulse motors
Started by Nastrand2000, September 16, 2007, 10:46:33 PM
Nastrand2000
I've concluded that if you want more power to the shaft then a wider coil is whats needed, but if you want more voltage out the a taller coil is needed.
Jason
Ren
tropes, Ive blown my last hall I have to order some more. I have two bung halls that stay on when power is connected. If I remember correctly those two were blown when I filled a cap past the 30 volts max recommended on the halls and accidently ran this voltage through the circuit, well the second time wasnt an accident. I believe they are fried beyond use now.
@ hoptoad, thanks for responding to my invite, I hope we can learn lots from your experience! Hopefully you can recommend some changes to our very simple circuits which will save our parts (and anger of our wives ;D). A shame to hear about your experience with the Adams polluter, do you think this  phenomenon  was due to the mechanical switching, something most of us in here no longer use?
Jase, thats awesome to hear your getting even lower running voltage, and charging bigger batteries! I am going to have to step up to keep up I think. I got my Bedini circuit running briefly (its playing up at the moment) and it was drawing 0.05 - 0.1 of an amp. Have not tried to charge anything yet. I need to start from scratch I think, build new wheel and new coils. Oh and I filled a 8000uf 80v cap to 40v off collector and emmiter of hall circuit. From your above post I assume that the cap will never fill to the level of voltage spikes, rather settle at an appropriate level dependant on cap sizing.
I hate running out of halls :'(
Ren
Oh and good to hear things are going well with treatment Tropes. By the way I found a more robust pnp for my hall -mjl21193. Its the pnp equivalent of the one Bedini recommends for his ssg. 10 bucks though.....ouch.
tropes
Yes Ren, it's good to be back. This hoptoad story intrigues me. I think it was you that originally used a mechanical switch on your motors. As was mentioned, one would think with recent catalytic technology this pollutant problem could be overcome. The main question however is: Was overunity achieved and documented. If so, this should be concidered as a great achievment.
Remember hoptoad; NO BULLSHIT ALLOWED!!!
BTW Ren, I just ordered 3 mjl21193 transistors from Futurlec Superstore.
Tropes
hoptoad
Quote from: tropes on September 23, 2007, 08:51:01 PM
Tropes
Yes Tropes, IMHO OU was achieved, though the effect was very feeble, and yes Martin fully documented all his experiments as did I during the period from 1990 to 2001. In my opinion, however, the source of this OU effect was not only feeble and of not much practical use, but also caused many problems besides the production of poisonous fumes. When using mechanical switching in such circuits, the RF interference not only affects runtime measurements with digital equipment, but extends way beyond the immediate environment to affect TV and radio reception for quite a radial distance. Many of my own neighbours knew when I was conducting such experiments because their TV screens would be affected by constant interference lines across the entire screen.
For this reason alone, to continue using mechanical switching is an open invitation to be visited by Telecommunication authorities
who may be investigating complaints about such RF interference lodged by people who have a right to know why their equipment is being bombarded by RF that is not licensed for the bandwidths affected.
In my own early mechanical switch experiments I was using a copper star commutator and gold plated relay point contacts, and I never once achieved the same apparent OU effect that Martin achieved with his machine. The fact that the effect only occurred using mechanical swiching is what led me to theorise, that the effect was due to the sparking, and had nothing whatsoever to do with "gating ether" or "negentropic energy" via the regauging process of the coils and magnets as Robert Adams continually claimed.
It is interesting to note also, that Adams himself intimated on many occasions that the use of semiconductors would negate any self charging effect.
I personally abandoned mechanical switching in my own Adam's designs early in 1992, and continued research using solid state switching for the remainder of the period till 2001. But with semiconductor switching I have never seen OU effects manifest even once.
