Neon extraction circuit tests
Started by ashtweth_nihilisti, September 19, 2007, 10:32:54 PM
ashtweth_nihilisti
Okay, we need to debug the circuit first,  we have new information which will be helpful for others and are adding in a new write up.
" debug the circuit in two parts as previously described on a low impedance dummy load, BEFORE connecting up to a battery.As described in the debugging scheme parts 1 and 2, starting with the neon
fully off, are you able to turn VR1 gradually so that the neon just starts to flash occasionally. If so, you should be able to begin to sense any over-loading at this stage (from the current draw and sound of the RV), and then back off VR1 so that you don't blow the fuse.If you don't notice any increased load when the neon is flashing occasionally, then you can continue to adjust for the neon to be on more (or most) of the time."
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
Jason
I requested your removal Hissy but the moderator option failed. So I am making it public and requesting your removal from this forum, to whom that may concern. Ashtweth is busting his butt to get open-source info. out there and what are you doing? He is simply relaying the info. that he is given and in the R and D mode of all technologies there are ups and downs but we must all maintain an excitement and faith that we will soon create FE in every community. He appears to take this a little more serious than you obviously do. There are 24,000 children who starve to death daily, there are 6,000 who die daily of aids. Over 3 billion people survive on less than $2 usd a day. Only 8% of the world own a vehicle. This is not someone else's problem this is yours and mine. Jason
jeffc
Quote from: HissyfitNihilism on September 27, 2007, 01:08:33 AM
Cheering while Ashtweth humps the leg of every free energy faker that comes down the pike will not feed any starving children or cure AIDS.  This is the truly sad part of the hypocracy going on here.  I fully expect to be removed at any moment.  Only idiots and their cheerleaders are truly welcome here.
I think banning anyone is a big deal.  Hissy, I'm not sure if your intent is to contribute to this forum, if even by skepticism, or if indeed your goal is to bully those here because you are completely against the goals of overunity.com.  If it is the former, then I would think you are welcome here, but if the latter, then I think it is the moderator's duty to strongly consider banning to keep the forum productive.
Again, skepticism and criticism are actually a necessary part of progress, we should not remove those negative types just because they are not "cheerleaders".  But criticism needs to be critical of the forum topics, and not personal attacks, and also posts that are just pure disruptions have no place here as well.
Regards,
jeffc
hartiberlin
Hi Ash,
looking forward to your new data.
I cleared out this thread from offtopic postings.
Regards, Stefan.
hartiberlin
user:
HissyfitNihilism
was banned from the forum due to spaming.
