Neon extraction circuit tests
Started by ashtweth_nihilisti, September 19, 2007, 10:32:54 PM
ashtweth_nihilisti
Hi All, hopefully we will get to these tests this weekend and trouble shoot with the inventor of the circuit, here is the neon peak detector which is configured to extract resonance from the RUN cap on the prime mover, David Kou (Inventor) reports this charging a secondary battery with no reflection to the first.
W are talking to him now and attempting to get him to walk us through the replication , will have videos and measurements soon.
The Half wave and Full wave is for the peak of the sine wave. Peak will extract more power.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
ashtweth_nihilisti
sorry circuit is attached,
Guys more people should try this
ashtweth_nihilisti
hartiberlin
Hi Ash,
interesting !
Did they measure, how much power was drawn from the
primary battery into the inverter during these tests ?
Okay, they only thing that was shown in this test was, that
the neon circuit could extract some 38 Volts rectified chopped DC voltage from the
neo circuit when loaded with 2 light bulbs.
Normally, if not loaded by bulbs this output charges up the secondary battery, right ?
Now it would be interesting to know,how much power was drawn during this test
from the primary battery.
Looking forward to more tests.
Regards, Stefan.
ashtweth_nihilisti
Hi Stefan,  Sure this was only a warm up, more tests coming today, Will measure primary and secondary
Yes the resistance makes the voltage drop! so we are hoping the battery will bring it down cant charge a battery with such high voltage :P. We are still learning about this circuit, form Daivd, yes usually it is used to charge a secondary.
