New accelerating lego magnet motor on youtube
Started by hartiberlin, September 21, 2007, 06:55:00 PM
Localjoe
@Jason O
Something ive found interesting is how a magnet's tangential pole has more power to push or attract given its placement.  Just play with two bar magnets , feel the field shape with one in repulsion and at a certian downward angle (magnet below another one like the stator magnets placement you talked about) you feel an even stronger push or pull then the normal head on one.  What would be beneficial is to take into account magnetic field shape and density to hit the sweet spot when the rotor passes .  Just a thought but the placement of the stator magnet has got to be the key so the rotor  kinda sling shots off of it.  If one would be able to find a formula that was for the diameter of rotor  vs the diameter of the stator magnet and the time the stator takes to do one revolution and the time the rotor takes to do one revolution. Once the proper diameters were found , timing that interaction precisely so that the rotor magnet gets the full push would yield a system of high efficiency and  incur much less loss because it would me a mechanical self resonate system . That would only leave the x and y coordinate spacing left to play with and would be much easier with the other variables eliminated.                                                             Joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Yadaraf
Quote from: Jdo300 on January 31, 2008, 07:00:33 AM
I personally feel that this motor may have some merit. Some people were talking about their being a hidden motor underneath the table or something, but if you look at how the thing is actually accelerating, it *seems* to be acting like it is moving because of the magnets. Now, with that being said, I didn't bother to look at the video frame by frame to see what the positioning of the magnets are. But even if they were going in the  wrong direction with the wrong polarities facing each other, I would still not discount it immediately. Anyone who has been following the MPMM replication will tell you that the motion of the anti-gearwise stator magnets is counterintuitive to say the least.
God Bless,
Jason O
@ Jdo300
Jason,
I've seen your CAD skills.  Nice.
If you grab a few screen shots from the Lego vid, and use the two base plates as "grids" you could probably dimension the device very quickly.  Add to that, Lego blocks and plates have standard 1" features, and 1/2" centered studs (I think ... I'm picking some up today).
I've started the reverse engineering process, but a second independent effort would be appreciated.  ;)
As for the magnets ... the bright colors and plastic case suggest they are from an educational supplier, thus size could be defined in either metric or imperial units.  They appear to be around 2.5" x 0.75" x 0.75" or 65mm x 20mm x 20mm.  I need to to do more sampling.  Although I've seen educational neo's that were encased in blue/red plastic, I doubt these are neo.
Cheers,
Yada ..
Omnibus
@Yadaraf,
Isn't the beauty of constructing this is that it's built of standard Lego elements? Why bother with CAD? The only problem is that nowadays one cannot find just a set of Lego pieces but everything is turned into this or that construction. I guess the profit is higher this way. So one has to buy a bunch of unneeded stuff to get the full set of pieces to assemble what one needs.
ken_nyus
Quote from: Yadaraf on January 31, 2008, 01:41:13 PM
Cheers,
Yada ..
Hey Yada,
I looked at legos a little while back.
They do indeed have standard units, but they are their own special Lego units, they have a name for them I forget what it is. The lego website is very helpful. The Lego units unfortunately do not fit into any other standard units.
On the Lego website they also have their own free Lego design software, sort of a basic CAD program for Lego builders. An interesting feature is you can design your Lego thing in this software, and then you can with a few clicks send an order to them and they will ship you all the parts that make up your design. I think you can even pay them to assemble it and package it in a box for you like a custom "toy".
It is also interesting that the individual Lego parts are made to a very, very high standard of precision.
Yadaraf
Quote from: Omnibus on January 31, 2008, 02:12:51 PM
@Yadaraf,
@ Omni
IMHO Lego CAD -- a.k.a. Ldraw -- will be a useful tool for documenting this device.
.... http://www.ldraw.org
In any event, I have to use a computer to reverse engineer the screen shots, which are quite distorted and blurry.  Specifically, I'm using a CAD program to rescale and resize the screen shots, which are skewed about 85% front-to-back.  I'm creating CAD rulers as I go along, using the base plate studs [centers] to calibrate the rulers.  I say "rulers" in plural, because the image skewing requires that I apply different rulers when dimensioning foreground vs background objects.  Also, the rulers allows me to dimension "Lego unknowns," like the magnets, spools, etc.
Even obtaining the length of the rotor support braces is tricky, because the supports are black and practically featureless, making it difficult to dimension the end caps in particular.  Difficult ... but not impossible.  I've already caught one or two dimensioning mistakes, so a second opinion from Jason would be useful.
Having said that, I'm making good progress.  :)
Cheers,
Yada..
