Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 20 Guests are viewing this topic.
ramset
GK that stun had goosebumps attached  thanks    Chet
Thanks Grandma
weri812
that was geeeeeeeeeeerrrrrrrrrrrrrrrrraaaaat. :o :o :o
neaded that :'( :'(
thanks GK
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
giantkiller
3, 6, 9. Mechanical(horizontal or vertical placement) or electrical.
1 layer layer = 3x turns,
middle layer = 6x turns,
3rd layer layer = 9x turns.
1 frequency gives the 3x heterodyning magnetically due to length of path traveled and the 3 field collision in the coil topology center. Extra energy.
A Telsa coil once again.
--giantkiller. Happy father's day. Past, Present and Potential.
giantkiller
We start out in the fertile cresent. There appear huge monoliths. The seat of power migrates to the British isles. There appear crop circles. Then the next large society is the mayans. There appear huge monoliths. Today there are huge displays in infrared above. The next seat of power is the U.S. There is Area51. Huge technological advances. Our progress across the planet has been tracked into all the continents.
Oddly enough, doesn't Stan Deyo look alot like Steven Mark in the videos?
--giantkiller.
giantkiller
Here we have 2 pancake coils (Primary and secondary) fired by a stun gun circuit to produce the Lenz law of inductive repulsion. This propells an aluminum projectile.
http://www.americanantigravity.com/massdriver.shtml
Lenz law in action.
http://www.americanantigravity.com/bushman.shtml
http://www.rexresearch.com/roschin/pitkanen.pdf
http://www.americanantigravity.com/graphics/marcus/Toroid-Mag-Coil-Type2.jpg
The spin factor in the deyo coil and the searle disc show the same spinning / counterspinning layers.
Tesla mentioned his favorite coil was the conical. But where and how many times do we see it? He states that if we could only see the power in 3,6,9. You could stack 3 coils on top of each other and wired in series. You would have a conical shaped field and a wide band resonator. In the Colo spgrs coil the center is a canistor shaped primary, open wound. Same as the outside surrounding secondary. There are no descriptions or wiring photos to show how that is hooked up. It could also be done in 3 seperate layers. We just assume the obvious.
Anybody seen the Deyo tensor coil around in the sites?
The rotating mag field is the way to get the high speed energy instead of pulsing high speed. With 3 freqs the center focus can be exercised from the center and spun. The vortex center can be manipulated. The aetheris spin the becomes the dialetric moving across the copper windings and incorporating magneto-hydrodynamic inertia. A magnetic field can be created and spun anywhere. This gives rise to propulsion in any medium.
-giantkiller.
