Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 46 Guests are viewing this topic.
acerzw
@all
Oh, and in addition to the above, just to nail the lid on the coffin, what are the two most common elements in the Universe? Only hydrogen and helium... so pretty much all of the matter in the Universe is likely to break the theory at one time or another... and of course the sun is 75% hydrogen... so when you look into the sky you see one of the largest slow burning OverUnity devices that exists... just incase you need proof it's there in front of your face (barring clouds) every single day of your life... quite a big clue huh! That must be a mega oops...
even the classically trained are beginning to wonder about Einstein...
http://www.comprsci.howard.edu/masspace.htm
but still attempting to rectify the paradox's his work leaves behind, alas...
And Einstein was clearly a clever fellow, hence I suspect after he discovered the error of his ways when he was confronted with Quantum Sillyness Theory, he probably decided not to publish his completed unified theory in the light of what was done with E=MC2, however he may have given it to the MIB's, or perhaps they took it from him, after his part in the dissappearing ship sillyness, so who know's what the final verdict on him will be... which of course will be reliably recorded by classical revisionist history... ho hum
Perhaps Tesla was wise when he told Russell to hide his cosmology... still I am sure that won't stop us  ;D
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
armagdn03
I wish I could turn my brain off sometimes, then I could get some sleep.
sparks
@armageddon
     I think what you are calling polarization is what I call energy form.  I believe there is energy in orbital or vortex form and there is energy in
linear or straight form.  The two energy forms do not convert into one
but interact.  Time is but a description of these two energy forms interplaying.  If all were the same twice would time have advanced?.  If
nothing changes does time advance?  What we call wave form of an energy is the play of vortex energy as it swims through a sea of linear energy. Earth is a greater concentration of vortex energy (where straight energy is bent into all sorts of directions) compared to space where straight energy predominates.  The vortex energy always attracting vortex energy the straight energy always trying to flow straight away. Magnetism is straight energy flow patterns while gravity is vortex energy flow patterns.  This balanced dance of two energy forms creates the universe.
     Einstein's greatest contribution to physics was his reference to the observer.  He described the Universe as being relative to an observer.  I believe he was right.  The observer is the mind, for without it there is nothing.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
acerzw
@sparks 'energy form' got me thinking....
@all
I have a radical solid-state vacuum energy device idea which I want to run past you..... it is as usual with me a bit far out... but here goes...
To fully understand this idea I recommend you read this great page, a link to which I posted on page 39...
http://www.timstouse.com/EarthChanges/ScienceOneness/chapter13.htm
You could search google video for "cymatics" too, an example:
http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=5860842
In summary a two or three dimensional form is created when a standing wave (or moving wave with the right frequencies) is contained or restricted by a barrier which is impermeable to it but reflects it. Adjusting the frequency of the wave source and the size of the barrier changes the shape created, so:
Now suppose we create a metal/wire sphere, which might need to be electromagnetically charged. Now we place in the centre of this sphere a perfect electromagnetic energy broadcast source perhaps a small metallic sphere, such that it can radiate electromagnetic pulses outward in an almost perfect spherical wave.
Using the principles of cymatics, we then tune the electromagnetic pulses from our central source so that they create a cymatic energy form inside the wire/metal sphere. This form of our choosing will have either node points (in the case of platonic solid forms) or points of high energy concentration (in the case of other patterns). Now I suspect if the pressure/stress created in the ether at these points was high enough then a specially designed energy capture probe placed at these points, by inserting through the spherical metal sphere/mesh, might have a reaction caused in it that allows it to extract vacuum energy. If the device was a metal sphere perhaps the probes could just be round plates built into its walls at the node intervals. (There might be anti-nodes to if Russell is correct that could be tapped too, or perhaps the potential between nodes and anti-nodes could be used?)
The design of the probe would probably have to include severals parts/elements organised in a specific way in order to create a potential which the vacuum energy under the extreme stresses would be obliged to fill in order to attempt to bring the system back into equilibrium. This might mean pulsing the probes with a field of some type.
In order to make the containment barrier effective it might need to be charged or pulsed in some way... as it needs to reflect the contained pulses... not absorb them...
This is kind of based on Russell and Keeley, but particularly Schauberger, who showed a very high pressure energy vortex has a central hi-stress nodal point at the center which can tap vacuum energy... The shape of the device also reminds me of Tesla's Wardenclyffe tower...
The tuning would have to be very specific in terms of the size of the sphere, the frequencies and materials used. But it seems logical to me that it would work. Plus depending on the Cymatic form created due to the frequencies used the number of nodes/high energy points can be increased (made very dense indeed) and thus the number of probes, increasing the output. Indeed if the correct structure design/material were used it might be possible to replace the probes with an internal three dimensional energy collection mesh made of wire in order to be able to tap internal high energy/stress points within the form, if the more complex forms were used... we must remember here that materials can be invisible to waves of certain frequencies so the right material could support a grid of collection devices yet not interfere with the wave energy.
This basic theory is semi-supported by the comment I have seen on other energy forums that the "Joe Cell" energy device is designed around a wave form, its concentric rings coincide with a wave form as shown in the Walter Russel energy diagram at the end of this post.
I do not think the input energy's would necessarily need to be high, just the frequencies, so the input output ratio might be pretty good. I can think of many variations of this idea, it seems to me to be a potentially important key...
Waves are three dimensional, we only use two dimensions in our current devices so are wasting tons of energy, we need to go 3D! Surely a "Joe Cell" of concentric spheres would be more efficient than the current design.  8)
If the sphere were filled with hydrogen, helium or water using the right frequency (possibly of sound) there might be enough energy at the high stress points to disassociate the molecules and produce excess heat (as described in my page 39 post). If the metal sphere of the liquid/gas is placed in a pressurised compartment filled with water the heat from the sphere would heat the water producing steam which could run a turbine to produce more energy. The liquid/gas in the internal sphere would need to be pumped through it and cooled at a later stage which would cause it to recombine and then it could be passed through the system again... a closed system. The energy produced on the output could be used to power the internal frequency generator thus creating a self-running system. This reactor design is documented in "Occult Ether Physics" by William Lyne. Can we say super efficient cold fusion reactor!
Someone, Tesla? probably did this already? A Cymatic Energy Form Generator...
A
giantkiller
Quote from: acerzw on December 22, 2007, 06:49:27 AM
In order to make the containment barrier effective it might need to be charges or pulsed in some way... as it needs to reflect the contained pulses... not absorb them...
This is kind of based on a Russell and Keeley, but particularly Schauberger, who showed energy vortex which have a central hi-stress nodal point at the center can tap vacuum energy... The shape also reminds me of Tesla's Wardenclyffe tower...
The tuning would have to be very specific in terms of the size of the sphere, the frequencies and materials used. But it seems logical to me that it would work. Plus depending on the Cymatic form created due to the frequencies used the number of nodes/high energy points can be increased and thus the number of probes, increasing the output. Indeed if the correct structure design/material were used it might be possible to replace the probes with an internal three dimensional energy collection mesh made of wire in order to be able to tap internal high energy/stress points within the form, if the more complex forms were used...
A
Given the size of Wardenclyffe, I bet Tesla could point to any intersection on the planet, through the planet, or ionospheric deflection. All or any of these transmissions could be time shifted to get to a certain focal point like the Tunguska event. Just like John Hutchinson does with the 3 frequencies. Not so far fetched is it?
The ionosphere is the containment chamber.
--giantkiller. Frequency equals matter. Well, if that is the case then frequency can move matter.
