Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
Schpankme
Quote from: giantkiller on December 31, 2007, 12:37:57 PM
The helical twist in the DNA is the same as the plasma arcs through the void of space like the 2 wire transmission line model.
Giantkiller,
Please answer the question - and do not PARROT another movie you just saw.
Questions
So, Transverse Waves and Wave Propagation traveling along a Transmission Line is the same as the helical twist of DNA ?
What's your understanding of Tesla, and Longitudinal Waves?
- Schpankme
EMdevices
What Erfinder posted about Tesla,  is a discourse about his Magnifying Transmiter, which we know as the TESLA COIL.
Due to the high inductance of the coil, the frequency of resonance is a lot lower then the free space resonant frequency for it's length,  so it is a very poor radiator, just like Tesla said, (only a small portion radiates away)
So if you don't have loses from it, the current and voltage build higher and higher as I'm sure we have all seen demonstrated.
The modern understanding of the Tesla coil is that it's an retarded velocity resonant system that sets up standing waves.   (you take the speed of light and realize that it goes round and round the tube or coil, and moves up or down very slowly due to the huge number of turns, so in essence the standing wave can occur at a lower frequency, which does not radiate well due to the mismatch with the free space wavelength at that same frequency)
EM
giantkiller
Quote from: Schpankme on December 31, 2007, 01:25:23 PM
Giantkiller,
Questions
- Schpankme
The wave is seen as the motion of the compressed region.
In the wireless transmission the planet is the source of energy and not the air. The vertical post at 2 places on the planet become 2 terminals of a capacitve power source. The planet has become a storage unit that we can get between its terminals and place 2 more terminals at smaller locations to extract of lower subsets of the stored power in the heavenly body. We can send tuned compresion waves through solid matter and receive it elsewhere. That is why the wireless patent shows 2 tuning forks in one of its drawings.
In all of the visible high energy pictures dealing with Tesla we see high energy being ejected into the air but not received.
Tesla held alot of information to himself. He saw that we as a people were united in ignorance.
--giantkiller. Nothing new here.
giantkiller
In the next 2 pix:
Yellow is ground
Blue wave is polarity A
Red wave is polarity B
Green is sine wave
First picture shows the AC sine wave. The magnetic field traverses in both directions.
Second picture shows the DC sine wave. The magnetic wave goes in one direction and the magnetic field rotates on its axis in one direction. Vector potential A aquired. Inertia through drag.
So here we have canon balls. Now pulse the wave from the aspect we are looking at when the magnetic field is at it maximum height. This would be bad.
The wave will add. And each successive rotation we will pulse it again and it will add and add and add. Real bad!
So we pulse it at a phase difference to achieve the desired power we want and below the stress level of the materials we have used to wind the coil with. I.E. variable speed drill. SM showed that to, didn't he? The amount of hidden clues are enormous!
How many feet of Romex/12awg at 60 hertz with a 60w lightbulb placed across the ends would it take to make a TPU. Use any harmonic size loops you want. The harmonic phase difference is controlled by the circumference,diameter.
Of course you will have to raise the AC signal up to a DC level of 0 or greater. Think Class 'B'.
Use sine waves to achieve a smooth gradient of the power curve to adjust phase incrementally. Square waves are either on or off. No adjustable power control. Ouch...
Besides, square waves eject the energy perpendicular to the conductor because the rising and trailing edges of the pulses are faster in some aspects than the copper can conduct. Think EM transmissions. This equates to lost power.
--giantkiller.
acerzw
A great year this is going to be for sure...
Great that 'Thunderbolts of the Gods' video, shows that people are waking up, even scientists!
Ironic though that they are revising a flawed Cosmology based on the Electric Model which is largely based on conventional flawed EM theory... just makes you wonder what they will discover when EM theory is finally sorted out and properly integrated into the Electric Model...
It is great that it supports the idea that the Universe is a web of energy both seen and unseen, as many Ancient Cultures said and new age theory now says. Now Tesla and Russell's theories can move out into the Universe where they always belonged...
And how cool about the sun... probably has a relatively cold center if it is only 6,000K on the outside...
You can kick me to death for saying this but, the hollow earth theory doesn't sound so bizarre now either... eek (what with the nasa video showing the corona coming out of a hole at the pole...) I can imagine several scenarios of an electrical nature where a solid shell can accumulate from debrise around a plasma shell caused by a small central sun, but where there are holes left at the poles because of the field flux ho hum...  ;D
For sure the ether is back to stay, I can't see the Electrical Model working without it... all that energy in the vacuum flux has to come from somewhere... negative entropy needs environmental energy to work... and it has to be ubiquitous and constant... that yells ether...
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
