Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
sparks
    An analogy of two magnetic fields mixing or hetrodyning whatever.  Two trucks going down the road in opposite directions.  The air currents or pressure waves due to their inertial energy is being compressed and relaxed along the boundarys of their mass.  These two trucks are actually heading on a collision course but as the bow shock of the vehicles meet it creates a compression field.  The trucks are diverted left and right around this compression field and the air currents coming off the trucks cause the compressed field to not only compress more but also to spin as it is being compressed.
The trucks loose no more energy then they would passing down the road far apart but they leave a little tornado right in the middle of the road that was never there before.  Man has created matter from thin air.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
aleks
Quote from: sparks on April 05, 2008, 08:21:41 AMMan has created matter from thin air.
Yep, and this vortex is created because on collision of air masses a standing DC acoustic wave is created which works as a local gravity force and thus creates a bit of non-linearity (impact wave itself may not carry DC acoustic waves as impact wave can be seen as propagation of synchronized acoustic waves, DC acoustic wave could be present the moment when the impact wave was created, though). Turbulence and sea-waves are all about this. It's so obvious I'm almost laughing nobody noticed it. :) Without such 'local gravity force' how do you think air masses can interact non-linearly as the air is otherwise a linear medium for any kinetic waves?
Interaction of two high-velocity impact waves can be also seen as interaction of two solid plates (because substance that carries impact wave is highly compressed in the impact wave cone), but when two solid plates slap each other, they do create DC kinetic wave component. It is this component which produces a gravity vortex and which can be sustained for a moment - in most cases it fades away, of course, as the air is basically a linear medium.
mflynn44
@GK
Is it your experience that the magnetic flux should move CCW in the upper coil and CW in the lower coil? I have one long wire making up my upper and lower coils with iron garden wire cores. Do you see two spikes appearing at almost the same time (I think generated within the lower coil)? Have you tried a 3" lower coil, a 6" middle coil to extract the energy, and a 9" upper coil? ( 3,6,9) Has anyone else seen a fog or mist emanating from their lower coil?
Don't let the distracters discourage you. We are close to solving this riddle. There are many possible configurations but only one basic principle.
sparks
  @ alecks
       I believe there are some kind of dc potential emitted or received at the poles.    There is a migration of hydrogen ions towards the north pole which pickup enough speed to escape Earth's gravity as a huge hydrogen plasma fountain.  At the south pole there are much heavier chlorine ions accumulating which don't escape Earth's gravity and are creating the ozone hole.  (Wish these would get the hell out of here.)  So beyond just solar charging of the layers of the ionophsere there seems to be some kind of dc potential between the holes in the ionosphere at the poles, ( as demonstrated by the selective ion migration.)   I don't know if this is some kind of energy exchange with the Sun but it seems to have happened on Mars before where whole Oceans of liquid got expelled at the poles.  Could gravity itself be some kind of DC field?
Think Legacy
Spread the Love
giantkiller
Quote from: mflynn44 on April 05, 2008, 11:46:12 AM
@GK
Tesla stated his favorite coil shape was the cone or trapezoid. That would mean big on the bottom. As far as the GK4 with iron cores goes I tested it on @ jan 1/ 2007 and then for 2 days after that. I felt the bodily effects and posted it. The reports back from those experienced in microwave and radio said not to touch it. The headache lasted 2 days so I disconnected the coil and never turned it on again. I basically created a microwave stun gun of sorts. I had 3 layers all pulsed in the same direction. Had I known at the time I should have pulsed the bottom layer CW and the top layer CCW then read the middle layer. All core layers are iron wire. Tesla mentions that also so I put 2 and 2 together when SM mentioned it. Only far fetched to those that couldn't see the simple suggestions. The rest of the wire runs are copper.
I choose not to argue with what was said and shown by Tesla, Keely, Schaumberger, Hutchison, Steven Mark, or Marco. There are others also that hold just as great respect. We all know the newbies don't want to read, build, or jump way outside the box. I don't blame them either. The thread count is massive. You just have to get on board here because academia is so far far behind the curve on this one.
And anyone who would aruge with who is mentioned here just doesn't get it.. Much pity for them souls. They wait at the gas pumps and complain in their darkness.
--giantkiller. Yes we are close. But the naysayers make for good coverup.
