Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
sparks
     You guys get any neutrinos whirring around the inside of your tpu's today?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Localjoe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
giantkiller
I have 1 segment of the GK4 hooked in.
The idea is to get the resonance correct so the resonant ringing lasts longer till lthe next pulse comes. I get 480 vp2p when that is not so. i have been able to get the ringing to last at least 75% of the cycle time with a duty cycle of 10%. I can change clocks or caps and coils.
That using my 555 timer box. It is not stable enough. I will switch to the ltc9604 and the xr2206 boxes.
I have to send in the scope for repair. The 1st channel is blown from last stun gun test. Using it is like walking through a house mirrors with one eye closed.
--giantkiller.
aleks
Quote from: giantkiller on April 22, 2008, 11:17:05 PMi have been able to get the ringing to last at least 75% of the cycle time with a duty cycle of 10%. I can change clocks or caps and coils.
At what frequency? Also, are you pulsing a single control coil or in chaser mode? (I guess 1 segment of GK4 means a single control coil is in use)
By the way, Tesla in his 382,282 patent suggests to use a lot of iron - not only for wires inside core, but also on top of "control coils", all around the toroid. Probably it could be a nice idea - you do not have to connect that outer coil to anything, only use it as an additional magnetic energy storage. Then again, core wires and this outside winding should create some magnetic flux space between them. This won't make the assembly more complex, but may extend the time of "ringing" after each pulse.
I guess those 3 greenish wire cores with 4 red control coils on top of each is your GK4?
(on another thought, have you considered that heart beat on oscilloscope looks like a pulse followed by a kick? I guess this thing should work similarly, with magnetic field/charge being a "muscle" that is contracted by pulses, the kick carries overunity energy we are looking for)
giantkiller
Quote from: aleks on April 23, 2008, 02:46:43 AM
That is the GK4. Each red coil of 29 gauge is a segment and only one layer. It is wrapped additionally with single trace of multistrand lamp cord by each segment also. So 12) 28awg segments ( high inductance) encompassed by 4) lamp wire segments (low inductance).
The iron casing will contain the magnet field and keep it from escaping into space.
The green wire is the iron wire. I have more and can get more.
--giantkiller.
