Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
Localjoe
Quote from: giantkiller on May 19, 2008, 12:24:21 PM
As another route
No iron core,
no magnets
Steel core
Copper controls.
On the first run the steel would not be magnetized. After power up it would be. Now we have our permanent magnet in place and our magnetic core or flux capacitor.
The magnet swipe in the open tpu is equivilant to the Bedini SSG motor kick to start things.
The air gap could sit anywhere on the any of the tpus. Who would've have known what to look for back then?
The iron core tpus would get warm. The GK4 got warm. Iron core, copper primary, copper secondary. The primary and secondary swap places with respect to the pulse level.
There are 2 patents referenced in the title 258767 & 266757. It is either a smoke screen, reference to people or some item.
--giantkiller
@ GK
I went through the same thing for a min going .. am i crazy these numbers are for clothing accessories. Those are "serial" numbers of patents one being the patent 382,282 and the other is one of the 381 numbers.... why patents have pat numbers and pat serial numbers is beyond me. One of the serials is a reference to another of his patents tho its not the hosiery one if thats what you found .. i got a good chuckle when searched them as pat numbers first.
        Joe
Bottom line is three of em deal with transformation and the others with distribution.. I bet he had to split them for legality  but it seems more clear that some paragraphs meant for one pat no were pasted to another one and so on through this series of 6 .....  sloppy work pat office.  All of this needs to be reassembled into the system he intended by laying out these  patents and figureing which modifications were needed almost each one has a flavor change.
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
giantkiller
Quote from: Localjoe on May 19, 2008, 01:22:57 PM
@ GK
        Joe
Well post the real pat numbers you found 'cause I was not going to waste my time on Gov mismagmt.
--giantkiller.
armagdn03
Quote from: innovation_station on May 19, 2008, 12:32:27 PM
pic
ist
Keep in mind I_S that if this core is solid, i.e. it is an electrical path all the way around the circle, it will act as a single turn secondary and kill all your energy and get very hot, this is how many high wattage soldering irons work, but im assuming you dont want to be making a heat machine. You need to put a break in it.
I wish I could turn my brain off sometimes, then I could get some sleep.
buzz-ard
Quote from: armagdn03 on May 20, 2008, 12:44:20 PM
Good call, armagdn. In Patent 381970, the iron core is sub-divided into four segments. Each segment is electrically independent. Each coil set contains the ends of two core segments, meeting in the middle. Insulation between segments can be added, or the segments can simply be spaced a few millimeters apart. The design can contain more core segments and matching coil sets.
This is my build for the week, finally. I plan to construct a sleeve from stiff paper or the like to facilitate winding the coils and sliding the core segments into them. Photos to come.
You wouldn't believe me if I told you.
giantkiller
Quote from: buzz-ard on May 20, 2008, 02:43:39 PM
Yep. I am in the middle of throwing parts for the design on the table at this very moment. Spent all weekend going over this plan to make sure of nothing wasted, including time. That's a killer.
My iron bundles are 3/4 inch thick and about 47 turns. That's 4" diam, 50ft.long  = 600 in / 12.56. Still need to compute turns for 5khz or 50hz?
The gap can be maintained by a sliver of shirt cardboard or construction paper. I guess you are going to make a loose collar for slipping on? That is a curve. Ouch. My design is with tight, single layer against the iron. The stability can also be maintained by sections of cable ties with the heads cutoff.
--giantkiller.
