Negative resistance via pyroclay.com material ?
Started by hartiberlin, October 02, 2007, 10:25:37 AM
RadiantEnRg
Sorry bout the spelling errors...I am tired and my keyboard is really bad about lil stuff blocking the buttons...anyway the videos need a couple minutes to finalize...but I hope this satisfies your suspicions about it being parasitic C.....I think I proved otherwise w/o a doubt now
RadiantEnRg
Hmmm...I don't know whats going on with videos, but if you go here you can see them.....they're Proof3 and Proof4
http://youtube.com/profile?user=RadiantEnrG
RadiantEnRg
I don't know whats up with youtube..it seems they may be suppressing me??...video says done..but not working
So I uploaded them to google
here they are..........         http://video.google.com/videoplay?docid=5391877654635220383&hl=en   &   http://video.google.com/videoplay?docid=-5057363605077932659&hl=en
Super
maybe this document from Alexander Frolov can help to understand what this setup shows ...
http://intalek.com/Index/Projects/Research/FreeEnergy.pdf starts with this at page 5
question is how to make it become useful OU  :D
tinu
Ok. Thanks for the videos. They are great!
I guess we have to continue our discussions after digesting all the arguments and after you taking some sleep. It must have been a very long night for you. And I appreciate your continuous efforts.
I suggest you bring also your friend into the discussion.
I?ll try on my side to get a decent video-camera and to replicate whatever will come out of this endeavor. (Right now I have only a still camera, which is very poor for making videos.)
Meanwhile, I?ll throw in some thoughts:
1. I was speaking about the battery as a first experiment only. But as soon as the voltage is raised (oscillator and ignition coil), the battery voltage become negligible as is superseded by the existing high voltages.
2. Unfortunately, for the car ignition coil, the primary and secondary are electrically connected. Ideally, for refined experiments, they would better not be connected. But being given the existing circumstances, the connection point between the primary and the secondary is the common ground. If it?s to judge various capacitances, I suggest being in relation to this point, which happens to be also the metal (conductive) case of the car ignition coil. Hence, the coil being placed on the ground, a strong coupling exists with the ground (floor, furniture& nearby objects, walls etc).
3. I don?t get it why the direct contact to the battery shuts the neon off (Prof3). This is a strange behavior. I wonder if you move the clip on the other diode, will the neon shut off too? This is something I have to dig on.
4. The white wire from the coil to the neon (clip) is actually something that introduces a large variability. Is the white wire connected to the above-spoken coil ground or to the other terminal of the coil? (It wouldn?t make much difference though, because of relatively high voltages and relatively low resistance of the primary winding but it is worth to know). Anyway, the fact that the neon is always light it means that a small current flows through the white wire. Basically the clip is splitting the blue neon in two capacitors. On one semi period the left part is conducting and on the other half, the right part.
5. Noticed that in Proof4, when the orange neon glows, the right side of the blue neon gets off? Well, what does it mean? To me it still looks like capacitive effects. Your fingers break the symmetry in capacitances and the blue neon shows it.
Keep on with your excellent work and accept my apologies for any language barrier you may rightfully feel as coming from my side.
Respectfully,
Tinu
