The final secret of free energy
Started by technobear, October 02, 2007, 02:27:18 PM
technobear
There have been many attempts at the final secret. Most of them arcane and complex and involving hideous maths. Well, like most things in nature, it actually turns out to be simple after all.
So simple that when it is finally proven to everyone's satisfaction, we'll be able to satisfy our energy needs for the next ten years just from the energy of so-called scientists kicking themselves!
Most researchers in OU seem to be hung up on one or another theory. Some are hamstrung by their own education. I'm not. I have read very far and very wide on this subject and I believe the answer is now becoming clear. Tesla of course knew the answer but he only teased everyone with it. His studies into radiant events started his thinking off but what he eventually discovered was much simpler.
Electricity isn't some mysterious substance that is set free from the aether by a radiant event or some other hocus pocus. Electricity is a vibration of the aether itself.
Cold electricity and hot electricity are the same thing. The only difference is the frequency. Cold electricity is high frequency AC. The reason it manifests during a radiant event such as caused by a sudden discharge of a capacitor is because such a shock causes the aether to resonate - like plucking a guitar string. The frequency of resonance is dependent only on the length of the conductor.
Just read that last sentence again.
Take a length of conductor and tap it electrically and it will resonate according to its length and the speed of light.
Wrap the conductor into an air cored coil (no iron because this will damp the resonance). Call it a secondary coil and wrap a simple primary around it and feed that primary with pulses at the right frequency (which can be half or even one quarter of the resonant frequency or probably any sub-harmonic) and the aether in the secondary will start to resonate.
It's like pushing a swing or tapping a pendulum.
Very soon that secondary will be producing large voltages and large currents and you'd better be connecting it to a load of some kind (unless you want to generate radiant events of course :-) ).
This is how the Tesla coil works. This is the big secret. It's that simple. The speed of vibration of the aether is the speed of light and if you resonate it in a conductor you can generate very big effects for very little effort.
That's it!
Now spread it all over the internet and lets see some real progress here!
gaby de wilde
ah ha,
I had already figured out that just using the word "resonance" triggers enormous debunkery. As if radio isn't credible or something. lol
Thanks for the info. :)
blog  | papers | tech | inventors  | video
armagdn03
I believe that this is quite well known and has been said before. But to expand upon this and give a little more depth to the discusion, Id like to clarify a few things.
Imagine an imbalanced charge...
This creates a voltage.
The effects of the voltage radiate out decreasing in power as they get further from the source. This is noted by Bearden as a source dipole, and he notes that since the dipole exerts a force over an infinite spans of space, it is in effect an infinite (or almost) source of energy.
The shape of this field (electrostatic) around the charge or source dipole is not constant, but ever changing. For example. If you have a positively charged plate, negative particles in the virtual photon flux, eather, space time etc, will pop into existence around the plate. These will in turn cause positive particles to pop into existence next to them, which will cause more negative particles to pop into and out of existence next to them.  The result is a wave of positive and negative particles continuously affecting each other.  This can be prooven. If you stack plates up, connect them in the correct order and fluctuate a voltage on two of the plates, the plates to the outside and inside of the oscillating plates.
And of course if you use these in a resonant circuit, you get....................Tesla's work, lol. (hint...he referred to the stacked plates as condensers)
I wish I could turn my brain off sometimes, then I could get some sleep.
lltfdaniel1
interesting,just have to find out the frequency of the conductor and then poke it to find out...
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
This frequency is given, approximately, by dividing the speed of light by the length of the conductor, and is dependent upon two properties embodied in the conductor,
