DISSOCIATING WATER, A KEELY Project
Started by hansvonlieven, October 03, 2007, 02:04:46 AM
hansvonlieven
G'day raburgeson,
From what I can gather Keely uses three different amplitudes for his three chords. And NO, he did not use brute power. He was using acoustic resonators only, without amplification.
If you are interested, I go into a lot of detail on this on my website http://keelytech.com
Hans von Lieven
raburgeson
I'm bogged down with three Projects now. I considered trying this in the past. It would take one big tank to contain the expansion, we considered pouring a cement tank. Never started it though, the information was less than I was hoping for, got it from rexresearch at the time. I wasn't considering brute force so much as the power it takes to produce a pure note, the higher the frequency the higher the power requirement. You are looking at signals above the audible spectrum so I inquired. I wish you every bit of luck.
Sanity101
This goes out to anyone who is listining,
        I have been playing with different plate setups for my fuel cell but Every time I turn on my fuel cell The water turns green. Could anyone tell me what im doing wrong?
ResinRat2
Quote from: Sanity101 on May 12, 2008, 09:53:53 PM
I've seen greenish water tinges in the past when parts of the copper wire were exposed beneath the surface of the liquid. The copper wire oxidizes and turns green. Could there possibly be copper wire in your setup that is exposed and immersed in your cell water?
Just a possible cause to look for.
rapttor
Hans, I don't know if you have already seen this, but it's a two part video on Dale pond explaining Keely's work pretty in depth, if you've already seen this then my appologies taking up your time,if not... hope it helps you in your work.
Part 1
http://video.google.com/videoplay?docid=9125003792513982191&q=dale+pond&ei=Ev8oSKq6GIemrwKIze2SCg&hl=en
Part 2
http://video.google.com/videoplay?docid=-5430570751600484561&q=dale%20pond&hl=en
-rapttor
Successfully Perpetually Failing at everything I do...
