hartiberlin
user:
Freenrg4me
was now banned.
I let his last posting stand here, so everybody knows why he is banned
now.
@Amigo,
maybe you still can try it again at 21 Mhz,
but I guess you will not see any radioactivity again there...
hartiberlin
Quote from: amigo on October 26, 2007, 11:51:43 PM
I tried measuring current but am not sure if my equipment is sensitive enough. Fluke scope shows 0.4mV across the 1ohm resistor, as described by doc.stiffler in Fig.09, but I do not know if that's real or not.
That would mean 0.4 milliAmps going through the LED
or
from the output of the oscillator circuit into ferrite transformer ?
I guess from your visual output it could be 0.4 milliamps through the LED,
as your LED seems to be not very bright and these modern LEDs
already put out such brightness as these current levels...
amigo
My God, what is that guy's problem, he seemed intelligent and knowledgeable from posts I read in the past. What a shame that he has these severe paranoid thoughts that the world is after him to get him. :(
Haven't I written that it was my first attempt in replicating, never claimed it was THE replication, just an attempt. My signal generator is built around MAX038 which is up to 20MHz capable chip, where does he get 10, maybe because I said the coil tuned at ~10. And it's a bastardized version of a signal generator, yet it works so it's a proof of concept.
The output of the MAX038 chip is routed through a 50ohm resistor to the 390pf mica cap which is part of the main circuit. I don't have any op amps after the chip to amplify the signal. The output signal is about 800mVp-p according to my Fluke 124 scope and it seems to be pretty noisy. I should really make at least a better output stage with higher p-p.
0.4mV measured was across the 1ohm resistor between the signal generator and 390pf mica cap, so basically before the ferrite core or the choke actually. So I guess it's 0.4mA current if we are to believe Ampere law. :)
I am not sure what mcd rating my white LEDs are, but they are not the brightest you can get nowadays. It's what I had handy...
DrStiffler
Quote from: amigo on October 27, 2007, 02:55:04 AM
Great Work!
You are to my knowledge the first person to make a public announcement of a great job in close replication of the basic circuit.
If I might, I would like to offer you some points that may help in moving forward;
1) Have you read on my web page the problem with the direction of the coil winds, both must match, one can not be clockwise and the other counterclockwise. Some strange and undesired things happen if this is not correct.
2) Do no connect any external mass to any of the circuit. When you add metallic mass to increase LED brightness you are moving into a totally different theory of operation and will be limited by capacitive coupling to the environment, back into the equipment. Your current circuit is close to the floating light shown at the top of my web page.
3) You most likely are not seeing the HV because you are not at the correct resonance. This is way a good function gen. comes in handy to find the correct frequency. I have found as many as three frequencies where the LEDS were (to the eye) the same brightness. I have shown on my web page one of many methods that could be used to improve on the eyes response. If this is your case then you would find the correct frequency by first finding the beat ones (noting them) and then with the Neon attached move through these spots to find the correct one.
4) The Al plate does not worth the same as mass does in Stefans example. When using a proto-board with the backing Al plate it need not concern you until you wish to use it as a parasitic amplifier, in which case you would drive the circuit by applying your signal to the outer most plate.
You do need the ability to tune the signal source, I have tried IC's and they do not offer the flexibility to trade off the complexity. A good old LC oscillator with a tunable coil works best.
5) The circuit will 'HUNT' the problem is to be sure it is not caused by your oscillator shifting from thermal changes in the components. But when a search coil is used to explore a working coil you will see a wide bandwidth of frequencies.
6) The more LEDS you add in series the higher the voltage will rise in the coil, don't hold back, start adding and retuning, when its right you will well know.
Continued good luck and coming advances.....
All things are possible but some are impractical.
DrStiffler
@amigo
Short note, I forgot to thank you for doing the radiation test. Peers have asked for this but my Beta counter would not work here.
Looked at the video, why not put it up on YouTube?
