Bruce_TPU
Evening all,
Well, after long hours, and several sore fingers, the coil is complete and soaking in a water bath to test it.  I have decided to wait a day or two before winding the secondary.  I want to do as Bill, and test it in the dirt first, pull it, and wrap it with a secondary.
Water Bath test:
Submerged
Voltage .410
Amperage  11.3 ma's
I think it will climb as it continues to soak.  I used a Rebar Iron for my center.  Even though my totals seem less then some using zinc core, I hope that it will assist with the voltage on the secondary , having an iron core, when pulsed underground.
Testing:
1)  My copper wire is the positive and my iron wire is the negative.
2)  When touched together, and held shorted, the voltage and amperage go to zero.  When touched quickly, the ma's drop to between 2 and 4 and then straight back up.
When let loose, of course the amperage and voltage goes back to what it was.
Picture below is of completed coil.  Except for the outer wrapping of cotton fabric that I have since added.
Cheers,
Bruce
Pirate88179
@ Bruce:
Nice large coil there.  I am somewhat shocked that your numbers were not higher.  Did you try a magnet on your core at any time prior to winding?  The reason I ask is that when I went to Lowe's Home center, the "iron re bar" they showed me had very little iron in it.  My "zinc" coated iron spike has mostly iron, very high content.  That is why I went with the galvanized iron spike.  But, we don't know what will happen in the ground do we, so possibly the re bar is better and the zinc coating may muck things up.  Remains to be seen.  It is freezing rain out now and about 23 degrees going even lower tonight.  I might not be able to bury anything for a few days.
Let me know if/when your readings go up after soaking.  You have many more layers than I so possibly it takes time to saturate.  Best of luck to you Bruce. (Edit)  PS where are your other two wire ends?  I was just re-looking at you photo and only see two leads?  I think there should be 4 correct? (2 ends of cu and 2 of fe)
Bruce_TPU
Quote from: Pirate88179 on February 12, 2008, 11:23:44 PM
@ Bruce:
Hi Bill,
Yes, I tried a magnet on the rebar.  Pretty confident it is iron.  Same with the wire.
As far as there being four leads, I have two buried at the start of my first wrap.  From what I understood, those were not used for anything.  JOE is that correct, or not?  I thought the make and break goes between the one iron and one copper, is that wrong or right?
Bruce
Pirate88179
@ Bruce:
Yes, let Joe answer that question.  I will say that my understanding is that you tie both cu and fe together and then those are the make/break leads.  that is why I started my second coil at the top so, with the second layer, I would end up back at the top.  (My first coil has 2 leads at the top, and 2 at the bottom)  I guess they could be left open.  All of my tests for voltage, etc. have been only with any 2 leads, not with them tied together, which I have not done yet so, it probably will not matter.  I just wanted to make sure you didn't tie them together or something.  Nevermind.
PS  These are a pain to wind are they not?
Bruce_TPU
Quote from: Pirate88179 on February 13, 2008, 12:11:14 AM
@ Bruce:
Hey Bill,
Don't scare me like that!  LOL  I was picturing myself trying to dig those two ends out.
And yes they are a pain to wrap.  I think I will try it your way next time.  Wrapping the copper all around with the cloth was very tedious.
So Bill, is you center core one of those galvanized nail spikes?  How long is it, and I think I read you have two layers.  What size copper did you use (gauge)?
Cheers,
Bruce
