Pirate88179
From my readings, that is not exactly clear.  He did use the pitchblende on his farm where he did a lot of his experimenting.  The glow was reportedly coming from his farm so if that had anything to do with it, I don't know one way or the other.  I just wanted to make clear that I am of the opinion it was not needed or required for his cells to work evidenced by his success on the road trip and in the river.
I don't think that pitchblende would glow although I am not an authority on any of that stuff. (or much else, ha ha)  It is radium ore and is not refined radium.  Radium is what they used to paint on watch dials so they would glow in the dark so...we may never know.
Bill
IotaYodi
Thanks Bill! The glow could come from the electric current going through the pitchblende. Certain chemical compounds will glow when an electric current passes through it.
What I know I know!
Its what I don't know that's a problem!
Cap-Z-ro
Maybe a phosphorous angle too...due to the natural affects being manifested.
Regards...
t3t4
Greetings,
I'm new to posting here but have been reading over this site for many years now. The problem I find, it's bigger then a phone book and who has time for all that? Just smack me if I repeat anything already suggested or otherwise mentioned, but I can't sit an read for weeks at a time..... I'm a doer, not a reader! The novels are for my wife, not for me,,,, I'll just wait for the movie! But in the mean time, I run my own experiments which is what I want to talk about here. I hope you understand that I don't have perhaps the genetic make up that might allow me to sit through endless reading. I'm half blind now, if I read any more I won't be able to type! Better to quite while still functional.....
I imagine that everyone here realizes this earth battery of sorts is something Nikola Tesla realized in the late 1800's. But there is an anode and a cathode to it all which is not located all in one spot or location. We all know that when we move a magnet across a copper wire that a transfer of energy occurs, right? We can cause or force an electron flow by using a magnetic field which gives us voltage in return via the copper wire. That's basic electrical "generation" which is an incorrect term. It should be named "convergence",,,, not generation, since it's the combination of multiple elements which cause or forced the reaction. Anyway, Tesla had it right, some believe this as fact and the rest fail. He designed and built Wardenclif tower which Is a brilliant concept, but it all worked on a resonant factor.
This tower could pull energy from the earth and the atmosphere otherwise know as the ionosphere, aether, etc. This would have been the ultimate earth battery of it's time. I too have stuck some rods in the ground and got results, but I quickly got to the point of diminishing return. The real power/energy lays between the earth and the outer space. Instead of going horizontal, how about going vertical? I do this now with varied results, but I can recharge any battery for free using the method I described.
Are any of you using areal's?
The interesting thing to me at least, when you go up wards, you find new power/energy. After a great deal of research and experimentation, I know the earth resonates at about 6HZ. The funny thing to me is, so does the human skull. The ionosphere resonates between 106 - 108 MHZ, or so I have read. Tesla was more or less in tune with nature, so for us to duplicate his reported results, we have to do what he did, use what he used and try for ourselves.
Everything he did relied on a resonant factor. We loose almost any possibility of resonance when we use the so-called "chip" due to resistance, power factor, and the fact that a chip can't vibrate well, if any at all. Resonance after all is nothing more then breaching or reaching the mechanical threshold of said component. At least as I see it that is.... A chip won't move, but a tube will. I know it sounds old and antiquated, but to do what Tesla did, shouldn't we be using the same components he used?
Perhaps I just see things differently, but Tesla did all of this at least 114 years ago, so what is taking us so long to catch up? I'm not there yet myself, but I think I'm on the right track.
Anyway, it's just food for thought. But I believe, if you tune a Tesla coil at two distinct but resonant frequencies, you can/could "pull" energy from the vacuum, aether or Ionosphere as I prefer to call it. This term is only negative pressure because there is a lack of pressure, that does not equate vacuum to me. It's like speaking of light when no light exists. You can't have a negative when there is no positive to counteract. So my thoughts: there is no vacuum in space, there is just space and the conditions by which it exists.
I do my best to break everything down, take it apart to examine the counterparts. So the above is only my theory of work already done.
We'll see where this goes I guess, but thanks for listening to my $0.02 worth.
t3t4
jeanna
OOPS wrong thread!!
My apologies. This belongs on the stubblefield speculations thread!
I will leave it because is is mostly relevant anyway.
Hmm I wonder if I am getting really close to the mark.
I want to repeat that the earth vibration has been showing itself to be 2.22MHz to 5.5MHz (the 5.5MHz is when I use 2 stubblefields and may indicate a doubling of phase, so 2.22MHz is a sure thing.)
This is NOT speculation or coming from some obscure source, it is coming from the earth battery every day I go outside and look at my probes.
It matters NOT whether the earth battery is 2 simple probes in the earth or augmented by a Stubblefield coil and touching a geodesic dome frame (a kind of ariel).
The voltage and mA changes with those details and differences, but the frequency is the same on a given day on either set of probes.
I find that at least an indication that the earth has a daily pulse.
If more people would join in the datalogging experiment we could see if my numbers in the west usa are the same as in the east usa or in Europe or russia, australia.
welcome t3t4,
This thread was quiet for over a year and just picked up again. I suggest you read the last 2 months of posts to see where we are working now, so you can be in sync, if you want to.
There are a few drawings I have made and some scope shots too.
At the moment MY personal thesis has moved to think as you indicate that the changing magnetic field which is changing without cost to us, is something we can use.
It is, however a changing magnetic field and as such will be beneficial to us only if we use an AC approach. (ac, or pulsed dc over time is the same thing afai am concerned.)
So, please join in the fun.
Make a pair of stubblefield generators (induction coils of a certain type) and lets go for it!
I will add 2 pics of 2 scope shots here from today.
The lower voltage one is the plain eb the higher voltage is the one with 2 Stub coils appended. The frequency setting of the screen  should be the same.
jeanna
BTW
If what I said made little sense it may be that the context belongs on the Stubblefield speculations thread... sorry again.
