0 Members and 57 Guests are viewing this topic.
Bruce_TPU
@ all
Thank you for the best wishes and pm's.  Very kind.   :)
I ran a base test this morning (I'm still under the weather, but feeling better.)  Indoors, just rechargeable battery and lamp, run time was just under 1 hour.
I hope to hook it up outside this afternoon and do the test.
Cheers,
Bruce
EDIT:
Well I ran the test outside and it lasted 1 hour and 9 minutes.  Honestly, not much difference, considering the bulb looked dimmer to start with then the inside test.
@ Bill,
Have we heard from our youtube buddy yet?
Pirate88179
@ Bruce:
No, no responses from the pm's I sent him on youtube.  I also invited him here so I hope we hear something from him or see him here soon.
Bill
sid10
@ All
found a site today  www.wickstore.com
they have wet bulb wick by the roll. This is the stuff that you slip over the instrument that does the wet bulb temperature test. The roll works out to about 4 cents a foot for braided cotton covering for the iron wire of our coils. Can't wait till payday.
Sid
edit
Should have said copper wire.
The only dumb question is the one that goes unasked.
Pirate88179
Great find Sid, thanks for posting the link.
Bill
georgemay
Quote from: sid10 on February 20, 2008, 10:21:55 PM
Sid
edit
@All
Actually I used similar insulation for BOTH wires.  Copper and iron.  This way I didn't need to insulate between layers.  Just wind the both wires until the end.  My coil used 5 twisted wires .023" dia. insulated with nylon braided tube 1/8 in diameter.  50' each wound on 3/4" iron core.
I never finished coil with 2 cotton strings wound between wires.  To many shorts to fight with.  Decided to buy on ebay nylon braided tube to insulate wires instead.
George
