This little piggy is going to market...
Started by Grim, October 29, 2007, 03:16:01 AM
Joh70
is interesting. why does it work. why is there no sticky point. this gauss gun uses only magnet force and no gravity. is better than a smot, i think. how does it function physically?
my first impression is, the additional steal-ball touching the magnet(s) take a short time to be magnetized and flips over polarity of exactly one ball (the last one) for a short time, which shots it away from the others. if this is true, it show, that metallic-material interferes with magnets and their timing.
karl
Hi Grim,
you have inspired me.
I`ve seen some videos about area15 this days.
Think about a raund track (tube) with four aircoils at 0/90/180/270? or other configuration.
What happens to a mass e.g. steelball (there should always be a mass to store and share the energy) which is pulsed at the right time and position ?
Maybe one pulse is enough to shoot the ball in the circle motion and you get 3 pulses back from the rest of the coils, rectify and collect and measure coulombs to one condenser.
Thats my project for sure.
The ball acts as e=m*c^2 storage device with a memory effect due to changing speed.
Backwardreaction could be canceled out due to high speeds in the super sonic range. Therefore the backwardreaction could act as inwardreaction followed by the next pulse. Understand?
Basicly the track follows one fieldline of the aircoil and therefore the ball itself acts as a complete core.
An infinitisemal magnetic core which is at the same time carrier for electrons and overlightspeed electrons (magnetic particles, electrons with extremly alterated orbitals in the range of e.g. 30cm=Trackradius).
People of this earth: this is X-mass.
Any further questions?
What ever you want to build (excentric mass, stabilized circular mass, circulating e-filed, circ. m-field....).
Do it this way.
The ball is a big electron, you know the rule: You Need a A-Vecor = E parallel M
The coils surface is in the same direction as the ball is propelled. The ball (or a magnet of any size, TPU)   is the carrier of a mass of electrons. Maybe Lorentz is astonished when the object is rotated which his force acts to.
...my inspiration due to your idea...
Best wishes
kafRLunkel
karl
...see the animation here:
http://en.wikipedia.org/wiki/Coilgun
...we could design a coilgun with feedback circuit coils or use back emf to feed next coil (differnt coils to match properties of BEMF).
...from this link:
"A large current is pulsed through the coil of wire and a strong magnetic field forms, pulling the projectile to the center of the coil. When the projectile nears this point the electromagnet is switched off and the next electromagnet can be switched on, progressively accelerating the projectile down successive stages. In common coilgun designs the "barrel" of the gun is made up of a track that the projectile rides on, with the driver electromagnetic coils around the track. Power is supplied to the electromagnet from some sort of fast discharge storage device, typically a battery or high-capacity high voltage capacitors designed for fast energy discharge. A rectifier is used to protect polarity sensitive capacitors (such as electrolytics) from damage due to inverse polarity of the current after the discharge. ->Here we could start<-
A superconductor coilgun called a quench gun could be created by successively quenching a line of adjacent coaxial superconducting electromagnetic coils forming a gun barrel, generating a wave of magnetic field gradient traveling at any desired speed. A traveling superconducting coil might be made to ride this wave like a surfboard. The device would be a mass driver or linear synchronous motor with the propulsion energy stored directly in the drive coils.[citation needed]"
Looking forward
Karl
