Single Wire Tests
Started by duff, October 31, 2007, 03:42:00 AM
duff
Erfinder once said: "Study comes first and then construction! How can you build what you don't understand?".
I was going back through Steven Marks statements and the following got me thinking again. No one has a definitive answer for what the kick is.
SM: I told you that the simplest form of over unity is a piece of wire and a voltage source. Anyone can actually connect it and measure. See for yourself the kick. NO coil no xmrs, just a kick. That should tell you learned gentleman that there exists a form of energy convertible and useable which is directly related to a simple piece of wire and instantaneous electron flow.
The following is my effort to understand the kick using a straight piece of wire.
duff
Charge on a capacitor, in coulombs:
q=cv = 470uf ? 37.8V = 17.7660 coulombs
Energy Stored in a capacitor in joules:
E=1/2CV2 = 1/(2 ? 470uF ? 37.82) = 744.54K joules
470uF capacitor charges to 37.8V and discharges in 32us
Calculated current:
i = Q/T = C ? ΔV/Δt = (470uF ? 37.8V)/20us = 888.30 amps
Total Wire Length:  62 inches of #18 stranded wire.
Discharge Path Resistance (wire+resistor+relays): 0.13Ω
Dale LVR-2 Power Wirewound Resistor 2 watts 0.02ohms 1%
I do not have the math skills to calculate the energy under the kick in the last two scope shots. If someone could do that it might make an interesting comparison.
duff
I removed the 0.01Ω resistor and attached the scope probes to the terminal block on the relay board where the 62 inch wire connects to the relays.
pese
this must be an L-C Resonating Coil !
nothings else.
it is "kick" on vial the switching relais.
you can also use other parts to switch simply way.
with voltages in 1Kv are , you can use "spark-gags"
likeTesla.
Pese
duff
Pese,
I am only attempting to do the basic test here as SM states.
-Duff
