Half baked magnet motor, but needs help with LUA script in FEMM 4.2
Started by Low-Q, November 07, 2007, 02:59:22 AM
Low-Q
Hi,
I have being playing with FEMM again, and constructed a dual contrarotary magnet motor, with a sum of 12kNm (BIG motor) in one complete revolution. The calculations was taken with steps of 10 degrees, but the result is too good to be true, so I need help to make two contrarotary rotors placed some distance apart to rotate with 0.5 degree steps. And then calculate the average torque in one revolution - that should be 720 steps each. I have been looking into the help file, but scripts is not my strongest side :)
Br.
Vidar
ken_nyus
You have a script you are happy with, but you just want to change it to rotate 1/2 a degree each step instead of 10 degrees?
Post the script and model here as an attachment, and I can take a look at it.
You will probably have to stuff them in a zip file to make it an acceptable attachment here.
